Allora un po di conti non mi tornano. Ho studiato un po le formule "uffciali" del sito dove presi le misure tipiche della turbina:
Lenz2 turbine
che qui riassumo brevemente:
Watts output = .00508 x Area x windspeed^3 x efficiency
Area in square feet ( height x width )
Windspeed in mph
Example: the 3 x 4 described above in a 15 mph wind and an alternator of around 75% efficient would have a power output of ;
.00508 x ( 3x4 ) x 15^3 x ( .41 x.75 ) = 63.26 watts
Efficiency would vary depending on the alternator and building techniques. The turbine as tested will function at 41% efficiency at the shaft. The alternators efficiency will vary depending on the load. If you have an alternator performing at 90% and a turbine at 40% then the overall efficiency of the machine would be .9 x .4 = .36 or 36% efficient. If the alternator is only 50% efficient then the overall efficiency would be .5 x .4 = 20% . As you can see the alternator efficiency plays a big part in the overall efficiency or what you would see for charging.
How large will it need to be to make a specific power output in a given wind...
Watts / ( .00508 x windspeed^3 x efficiency) = total square feet of area
Example: Lets say we want 63 watts in a 15 mph wind using the number from above;
63 watts / ( .00508 x 15^3 x (.75x.41)) = 11.94 sq ft ( or a 3ft diameter x 4 ft tall )
How fast will it run in a given wind speed...
Windspeed x 88 / ( diameter x 3.14 ) x TSR
Windspeed in mph
diameter in feet
the "88" is simply to convert the mph to feet per minute
The TSR ( tip speed ratio ) for this machine for peak power is 0.8. Because it is a hybrid lift/drag machine in order for it to extract energy from both the upwind and downwind wings it needs to run slightly slower that the wind. 0.8 seems to be optimum while loaded although it will run at 1.6 unloaded.
Example: The same turbine in a 15mph wind loaded to 0.8 TSR...
15mph x 88 / ( 3 x 3.14 ) x .8 = 112 rpm
or unloaded - 15 x 88 / ( 3 x 3.14 ) x 1.6 = 224
Secondo queste formule una turbna di altezza 1,71 mt totali e larga 1 mt riuscirebbe a produrre solo 20W. Possibile? Inoltre si legge che questa turbina (nella versione classica ad un solo "piano") ha TSR pari ad 0,8. Sarebbe peggio di una savonius adirittura?
eppure la mia con vento di 1,5 m/s gira a circa 60RPM e qualcuno mi disse che corrisponde a circa TSR 3.Parlo di velocita' a vuoto ovviamente. anche se la differenza sta nel fatto che la mia e' doppia.
Ma in sostanza ... riesco a tirar fuori qualchosa dal mio ISOFLUX da 400W con questa turbina oppure e' un tipo di turbina troppo poco efficente?
Mannaggia mi manca il tempo ... voglio provare ad attaccarci una moltiplica piu' grande per vedere di generare anche sui 2 - 2,5 m/s. almeno 1:9 ma ho paura che mi manchi la coppia necessaria. Non c'e' proprio nessuna modifica che posso fare senza perdere in efficenza? Per ora ho questo generatore e non ho il tempo materiale di mettermi a costruirne uno alla piggot...
Come calcolo il TSR con precisione della turbina superiore per farne altre 3 pale con lo stesso TSR da mettere nella parte inferiore? Hanno altezze diverse quindi varia la superfice quindi immagino anche il TSR ... o sbaglio?
fabrizio
