vi posto una mail che e' comparsa per brevissimo tempo sul forum di MEG-Builders di Yahoo.Non so per quale motivo e' stata rimossa:per corretezza non rivelero il nome della persona che l'ha postata.
Detto questo vi conviene leggerla poiche finalmente da' una risposta alle domande sul MEG:
>Ever since I first ran across J. L. Naudin's Web site, I've been
>looking at his data as a round of the fun "find the other guy's stupid
>mistake" game.
>It didn't take me long to recognize that his output voltage and
>current figures disagree with the stated load resistance by an order
>of magnitude or more, or that pumping 28W into a 1W carbon comp
>resistor should produce smoke and flames which are notable by their
>absence.
>The data provided don't make it possible to determine whether these
>discrepancies are the result of dumbnitude or deception. End of story
>there, but from an electronics geekery POV there were still some
>apparent anomalies:
>The drive circuit is a garden-variety switching inverter, which should
>produce a square-wave output. The output voltage and current, and the
>primary current, are sinusoidal. WTF?
>The output voltage is nearly twice as high as would be predicted from
>the voltage swings available in a center-tapped push-pull drive
>circuit and the transformer turns ratio. WTF?
>Naudin reports that removing the magnet reduces the output
>voltage. Anyone who has ever worked with transformers knows that DC
>flux in the core contributes nothing to the output and is generally
>considered a Bad Thing.
>WTF?
>I think I've got it sussed. The key to understanding it is to replace
>the transformer in the circuit diagram with an equivalent circuit of a
>real-world transformer, you know, the one with an "ideal transformer"
>and the parasitic reactances and resistances reflected to one side of
>the transformer.
>Basically, the load reflected to the primary consists mainly of the
>transformer's leakage inductance in series with the parallel
>combination of the secondary's distributed capacitance and the load
>resistor.
>This circuit will exhibit series resonance, that is, the impedance
>magnitude will pass through a minimum at a frequency determined by the
>LC product (and detuned slightly by the R in parallel with the
>C). Below resonance, the impedance will be capacitive, at resonance
>resistive and above resonance inductive.
>That explains the sinusoidal primary cirrent. That's exactly how a
>series tank will behave if you whang a step voltage change across it.
>From the point of view of the load, we can replace the ideal
>transformer of the equivalent circuit with a voltage source reflected
>from the primary drive circuit. This generator drives the load
>resistor via an L-section consisting of the leakage inductance in
>series and the distributed capacitance in shunt- in other words, a
>second-order LCR low-pass filter.
>Now, the voltage transfer function of such a filter being wn^2/(s^2 +
>d*wn*s + wn^2), where wn= filter natural frequency, d= filter damping
>factor and s= complex frequency, when s=jwn (the condition for drive
>at the filter's natural frequency) the transfer function magnitude =
>1/d. If d<1 then the transfer function magnitude is >1; as d is
>reduced the filter becomes more and more "peaky". d is inversely
>proportional to the load resistance; the lighter the load the peakier
>the response.
>That explains the voltage boost. The output circuit of the MEG is a
>seriously underdamped low-pass filter driven at its natural frequency,
>that is, right at the response peak. The attenuation of harmonics by
>the filtering action explains the fairly clean-looking sine wave seen
>at the load.
>This also explains why the thing has to be wound for such a high
>output voltage. Increasing the number of turns in the secondary
>increases the leakage inductance seen looking into the secondary and
>also increases the secondary's distributed capacitance. Since the
>natural frequency of the network formed by thee parasitics is
>inversely proportional to sqrt(LC), adding turns reduces the
>transformer's self-resonant frequency, until it eventually coincides
>with the drive circuit switching frequency.
>A quick estimate based on a 25 kHz operating frequency, a 100k
>resistive load and a d of 0.5 (about right to account for the output
>voltage boost) gives me Lleak=318 mH and Cstray=127 pF. (roughly- I'm
>not accounting for the detuning effect).
>Are these realistic values? A bit over 100pF doesn't seem unreasonable
>for a 1500 turn secondary, which must include several feet of wire. As
>for the leakage inductance, a secondary leakage of 318 mH seen looking
>into a winding where the magnetizing inductance is around 5.7H is
>rather high- that would be a pretty s****y transformer by normal
>design standards.
>Naudin's transformer design is a veritable checklist of Things Not To
>Do if you want to minimize leakage inductance:
>1. Wind the coils short and fat so that as many turns as possible are
>spaced as far as possible from the core.
>2. Wind the coils on separate bobbins and mount them separately on the
>core (About the only time you see this in a practical transformer is
>when primary-to-secondary isolation is a paramount concern; usually
>one winding will be wound over the other or the two will be
>interleaved or wound bifilar to minimize leakage).
>3. Stick a magnetic shunt in the core to divert some of the flux
>induced by the primary and prevent it from linking the secondary
>winding.
>That brings us to the role of the magnet. Entirely apart from
>producing a DC flux in the core, it's acting as a chunk of
>magnetically permeable material which "short-circuits" some of the
>flux induced by the primary. That will act to increase the
>transformer's leakage inductance. The DC flux might also play a role-
>if the core is biased near saturation its incremental permeability
>will be reduced, which will reduce the magnetizing inductance and
>increase the leakage inductance.
>That explains why removing the magnet reduces the output
>voltage. Without the magnetic shunt in place, the leakage inductance
>decreases, increasing the natural frequency of the network formed by
>the parasitic reactances, so that the magnitude peak is no longer at
>the drive frequency. In other words, it throws the filter out of
>alignment.
>The experiment of removing the magnet is a great example of failing to
>isolate variables. Taking the magnet away or installing it
>simultaneously changes two variables: it alters the magnetic circuit
>of the core and it adds or removes the DC flux. Assuming that a change
>in circuit operation is entirely due to the latter is unjustified; the
>correct way to test the effect of the DC flux would be to remove the
>magnet and replace it with a nonmagnetized but otherwise identical
>piece of identical material, or to replace the permanent magnet with
>an electromagnet and compare circuit operation with the electromagnet
>energized or not energized.
>Basically, it looks to me like Naudin has stumbled on a variant of the
>series resonant converter and doesn't recognize it because the
>components forming the resonant circuit are the invisible parasitic
>reactances of the transformer, and because he hasn't enough experience
>with transformers to remember that those invisible components are
>there.
>A few years working in pro audio, contending with output transformers
>that show ultrasonic peaks and ringing without a terminating
>resistance connected to the secondary and with passive filter sets
>designed back when everything had tubes and 600 ohm source and input
>impedances which show wildly peaked responses when operated under the
>very low source z and high input z conditions found in modern audio
>gear should cure that aspect of Naudin's ignorance. Perhaps.
>Anyway, if you want, give me a few days and I can whomp up a couple of
>equivalent sche's (easy) and try to work as much of the math as I can
>(yuck). I hope that this basic qualitative description might be
>enough, and that you have time to let me know what you think.
Purtroppo il mio inglese non e' buono e quindi non sono riuscito a comprendere tutto ,ma la buona parte di quello che ho capito mi ha fatto cadere gli ultimi dubbi che avevo sul MEG di Naudin.
LinkBack URL
About LinkBacks
Rispondi quotando
