Scusate la domanda da ebete: ma dove trovo scritto http://localhost/ devo inserire http://raspicocchia.ddns.net/ (nel mio caso)? Ovunque? anche nel file rc.local?
sudo cp sdm120c /usr/local/bin/
pi@pi-alarm ~ $ sudo -s
root@pi-alarm:/home/pi# echo "options w1_gpio gpiopin=24" >
/etc/modprobe.d/w1
# device tree config dtoverlay=w1-gpio,gpiopin=24
http://192.168.2.102/php/measureit_functions.php?do=summary_sensor&sensor=0&timeframe=static&unit=HOUR&unit_return=timeframe&unit_value=2&table=measure_watt&select=time&range_from=false&range_to=false
sudo apt-get install git libmodbus-dev
pi@raspberrypi ~ $ git clone https://github.com/gianfrdp/SDM120C
pi@raspberrypi ~ $ cd SDM120C/ pi@raspberrypi ~/SDM120C $ make
pi@raspberrypi ~/SDM120C $ ./sdm120c /dev/ttyUSB0
pi@raspberrypi ~/SDM120C $ ./sdm120c -z 10 /dev/ttyUSB0 Voltage: 218.30 V Current: 0.00 A Power: 0.00 W Power Factor: 1.00 Frequency: 50.00 Hz Import Active Energy: 6409 Wh Export Active Energy: 0 Wh Total Active Energy: 6409 Wh
pi@raspberrypi ~/SDM120C $ sudo cp metern/comapps/pooler485.sh /var/www/metern/comapps/ pi@raspberrypi ~/SDM120C $ sudo chmod +x /var/www/metern/comapps/pooler485.sh pi@raspberrypi ~/SDM120C $ sudo ln -s /var/www/metern/comapps/pooler485.sh /usr/local/bin/pooler485
touch /run/shm/metern1.txt chown www-data:www-data /run/shm/metern1.txt su -c "pooler485 1 2400 /dev/ttyUSB0 &" www-data /usr/bin/curl http://localhost/metern/scripts/bootmn.php
pi@raspberrypi ~/SDM120C $ sudo -s root@raspberrypi:/home/pi/SDM120C# su -c "pooler485 1 2400 /dev/ttyUSB0 &" www-data
cat /run/shm/metern1.txt | egrep "^1\(" | grep "*Wh)"
cat /run/shm/metern1.txt | egrep "^1\(" | grep "*W)"
sudo adduser www-data dialout
