quali vantaggi da un generatore direct drive
  • quali vantaggi da un generatore direct drive
    vorrei capire bene che vantaggi puo dare un generatore direct drive e di che elettronica di controllo ha bisogno, considerato che un sistema eolico deve avere un cut-in di
    3-4 m/s??
    Ciao Nicolawind,
    ho esperienza solo su grosse potenze, nelle piccole mini e microeolico non credo dia dei grossi vantaggi in termini prestazioni/affidabilità/investimenti...
    Sotto hai dei dati precisi ai quali riferirti.
    Per le piccole potenze meglio un semplice ma affidabile generatore a magneti permanenti.
    Atima
    Lightweight ironless-stator PM generators for direct-drive wind turbines
    IEE Proceedings - Electric Power Applications
    E. Spooner,1 P. Gordon,2 J.R. Bumby,1 and C.D. French3
    1University of Durham, School of Engineering, UK
    2University of Durham, Evolving Generation Ltd, School of Engineering, UK
    3University of Newcastle upon Tyne, Electrical Drives and Machines Group, UK
    A permanent-magnet electrical machine that employs lightweight spoked structures for both rotor and stator is described. The stator is ironless so that there is no direct magnetic attraction between rotor and stator. The lightweight structures are sufficient to carry the small forces due to the interaction of the permanent magnet field with the stator winding current. Despite the absence of stator iron and a large airgap, rare-earth magnets are able to create a working flux density of about 0.25 T at the winding. This is sufficient for an effective generator design because the lightweight structures offer the opportunity to build generators of unprecedented diameter. The outcome is a generator that has a mass typically 20–30% of equivalent designs based on iron-cored magnetic circuits, and with efficiency greater than 90%.
      Per i generatori a magneti permanenti potrei pure essere daccordo, ma poichè ho già realizzato dei protoipi, testandoli mi sono accorto che la bestia nera (per i suddetti motori) è il numero di giri, e questo mi costringe ad utilizzare necessariamente un moltiplicatore di giri......
        Assolutamente no!
        Anzi....
        Basta farseli progettare e realizzare in funzione delle tue esigenze, o meglio, delle esigenze delle tue macchine. Aumentando il numero di poli diminuisce la velocità necessaria per generare la stessa potenza!
        Sono nozioni elementari... <img src=">
          sacrosanto, ma mi faccio progettare e produrre un motore per fare un prototipo?? non mi considererebbe nessuno. Da dove potrei comprarli??
            atimameg,
            hai citato dei generatori con statore "ironless" dove il flusso e' di soli 0,25 Tesla.
            Non credo che questa sia la strada da seguire, se non per casi molto particolari.
            Il flusso dovrebbe essere almeno 4... 6 volte tanto per avere un generatore compatto.
            Mario
