Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'. The request failed with the error message: -- Server Error in '/SSPWEB_DL' Application.
Could not load file or assembly 'App_Code' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileLoadException: Could not load file or assembly 'App_Code' or one of its dependencies. There is not enough space on the disk. (Exception from HRESULT: 0x80070070)
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. |
Assembly Load Trace: The following information can be helpful to determine why the assembly 'App_Code' could not be loaded.
WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. |
Stack Trace:
Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082 --.
Dettagli
Errore di Accesso ai Servizi
E' mai possibile che un sito istituzionale funzioni in questo modo? E noi abbiamo i nostri soldi in mano a questi che non sanno neanche gestire un sito Web? Siamo il paese dei "cachi", aveva ragione Elio!
