Misuratore di consumi con seriale RS485 - SDM120 - EnergeticAmbiente.it
  • hai provato un reboot del raspberry ?
    • Si provato reboot, ma non cambia niente.
      Puoi provare questa?
      pi@raspberrypi ~/SDM120C $ sdm120c -a 1 -b 9600 -P N -w 15 -d 1 /dev/ttyUSB0
      20170422-10:46:42.302569: sdm120c(31757) cmdline="sdm120c -a 1 -b 9600 -P N -w 15 -d 1 /dev/ttyUSB0"
      20170422-10:46:42.304870: sdm120c(31757) szttyDevice: /dev/ttyUSB0
      20170422-10:46:42.306356: sdm120c(31757) devLCKfile:
      20170422-10:46:42.307490: sdm120c(31757) devLCKfileNew:
      20170422-10:46:42.309638: sdm120c(31757) PID: 31757
      20170422-10:46:42.311683: sdm120c(31757) Attempting to get lock on Serial Port /dev/ttyUSB0...
      20170422-10:46:42.312597: sdm120c(31757) Acquiring shared lock on /var/lock/LCK..ttyUSB0...
      20170422-10:46:42.314027: sdm120c(31757) Shared lock on /var/lock/LCK..ttyUSB0 acquired...
      20170422-10:46:42.314609: sdm120c(31757) Checking for lock
      20170422-10:46:42.316967: sdm120c(31757) errno=0, bRead=2 PID=31757 LckPID=31757
      20170422-10:46:42.318881: sdm120c(31757) Checking process 31757 (sdm120c) for lock
      20170422-10:46:42.319317: sdm120c(31757) PID: 31757 COMMAND: "sdm120c" LckPID: 31757 LckCOMMAND: "sdm120c" LckPIDcommand "sdm120c" = me
      20170422-10:46:42.320621: sdm120c(31757) Appears we got the lock.
      20170422-10:46:42.320900: sdm120c(31757) resp_timeout=200000us
      20170422-10:46:42.321220: sdm120c(31757) Libmodbus context open (9600N2)
      20170422-10:46:42.322457: sdm120c(31757) Byte timeout disabled.
      20170422-10:46:42.322758: sdm120c(31757) New response timeout: 0s, 200000us
      20170422-10:46:42.331559: sdm120c(31757) 1/1. Register Address 30001 [0000]
      20170422-10:46:42.533970: sdm120c(31757) ERROR (110) Connection timed out, 1/1, Address 30001 [0000]
      20170422-10:46:42.535142: sdm120c(31757) Response timeout gave up after 200546us
      20170422-10:46:42.537796: sdm120c(31757) devLCKfile:
      20170422-10:46:42.538128: sdm120c(31757) devLCKfileNew:
      20170422-10:46:42.538392: sdm120c(31757) Clearing Serial Port Lock (31757)...
      20170422-10:46:42.539686: sdm120c(31757) Acquiring exclusive lock on /var/lock/LCK..ttyUSB0...
      20170422-10:46:42.540854: sdm120c(31757) Exclusive lock on /var/lock/LCK..ttyUSB0 acquired (0) Success...
      20170422-10:46:42.542179: sdm120c(31757) cmdLen=7
      20170422-10:46:42.543162: sdm120c(31757) cmdLen=7 COMMAND is not null
      20170422-10:46:42.543516: sdm120c(31757) errno=0, bRead=2 LckPID=31757 PID=31757 COMMAND='sdm120c'
      20170422-10:46:42.544475: sdm120c(31757) errno=0, bRead=-1 LckPID=31757 PID=0 COMMAND=''
      20170422-10:46:42.546066: sdm120c(31757) Clearing Serial Port Lock done
      NOK
      20170422-10:46:42.547645: sdm120c(31757) NOK
      • Gli altri valori del mio è perché questo è l'SDM 220Modbus
        questo è il risultato per un SDM 120 Modbus
        root@raspberrypi:/home/pi# sdm120c -a 1 -b 9600 -P N -w 15 /dev/ttyUSB0
        Voltage: 227.00 V
        Current: 0.24 A
        Power: 44.00 W
        Active Apparent Power: 54.48 VA
        Reactive Apparent Power: 28.10 VAR
        Power Factor: 0.78
        Phase Angle: 0.00 Degree
        Frequency: 50.04 Hz
        Import Active Energy: 3351465 Wh
        Export Active Energy: 0 Wh
        Total Active Energy: 3351465 Wh
        Import Reactive Energy: 0 VARh
        Export Reactive Energy: 0 VARh
        Total Reactive Energy: 0 VARh
        OK
        • Puoi mettere l'opzione -d 1 per il debug?
          • ecco il tuo test: ( su SDM 120)
            root@raspberrypi:/home/pi# sdm120c -a 1 -b 9600 -P N -w 15 -d 1 /dev/ttyUSB0
            20170422-10:55:07.872129: sdm120c(22731) cmdline="sdm120c -a 1 -b 9600 -P N -w 15 -d 1 /dev/ttyUSB0"
            20170422-10:55:07.872601: sdm120c(22731) szttyDevice: /dev/ttyUSB0
            20170422-10:55:07.872876: sdm120c(22731) devLCKfile:
            20170422-10:55:07.872946: sdm120c(22731) devLCKfileNew:
            20170422-10:55:07.873044: sdm120c(22731) PID: 22731
            20170422-10:55:07.873173: sdm120c(22731) Attempting to get lock on Serial Port /dev/ttyUSB0...
            20170422-10:55:07.873293: sdm120c(22731) Acquiring shared lock on /var/lock/LCK..ttyUSB0...
            20170422-10:55:07.873383: sdm120c(22731) Shared lock on /var/lock/LCK..ttyUSB0 acquired...
            20170422-10:55:07.873530: sdm120c(22731) Checking for lock
            20170422-10:55:07.873715: sdm120c(22731) errno=0, bRead=2 PID=22731 LckPID=22724
            20170422-10:55:07.873786: sdm120c(22731) Checking process 22724 (aurora) for lock
            20170422-10:55:07.873896: sdm120c(22731) PID: 22731 COMMAND: "sdm120c" LckPID: 22724 LckCOMMAND: "aurora" LckPIDcommand "aurora"
            20170422-10:55:09.829394: sdm120c(22731) errno=0, bRead=2 PID=22731 LckPID=22731
            20170422-10:55:09.829494: sdm120c(22731) Checking process 22731 (sdm120c) for lock
            20170422-10:55:09.829605: sdm120c(22731) PID: 22731 COMMAND: "sdm120c" LckPID: 22731 LckCOMMAND: "sdm120c" LckPIDcommand "sdm120c" = me
            20170422-10:55:09.829673: sdm120c(22731) Appears we got the lock.
            20170422-10:55:09.829733: sdm120c(22731) resp_timeout=200000us
            20170422-10:55:09.829827: sdm120c(22731) Libmodbus context open (9600N2)
            20170422-10:55:09.829885: sdm120c(22731) Byte timeout disabled.
            20170422-10:55:09.829940: sdm120c(22731) New response timeout: 0s, 200000us
            20170422-10:55:09.835567: sdm120c(22731) 1/1. Register Address 30001 [0000]
            20170422-10:55:09.894597: sdm120c(22731) Read time: 58951us
            20170422-10:55:09.894667: sdm120c(22731) reg[0/1]=17253 (0x4365)
            20170422-10:55:09.894723: sdm120c(22731) reg[1/1]=45875 (0xB333)
            Voltage: 229.70 V
            20170422-10:55:09.894867: sdm120c(22731) 1/1. Register Address 30007 [0006]
            20170422-10:55:09.954718: sdm120c(22731) Read time: 59794us
            20170422-10:55:09.954772: sdm120c(22731) reg[0/1]=15989 (0x3E75)
            20170422-10:55:09.954822: sdm120c(22731) reg[1/1]=49807 (0xC28F)
            Current: 0.24 A
            20170422-10:55:09.954909: sdm120c(22731) 1/1. Register Address 30013 [000C]
            20170422-10:55:10.014847: sdm120c(22731) Read time: 59876us
            20170422-10:55:10.014909: sdm120c(22731) reg[0/1]=16944 (0x4230)
            20170422-10:55:10.014965: sdm120c(22731) reg[1/1]=26214 (0x6666)
            Power: 44.10 W
            20170422-10:55:10.015049: sdm120c(22731) 1/1. Register Address 30019 [0012]
            20170422-10:55:10.077482: sdm120c(22731) Read time: 62367us
            20170422-10:55:10.077544: sdm120c(22731) reg[0/1]=16979 (0x4253)
            20170422-10:55:10.077599: sdm120c(22731) reg[1/1]=21234 (0x52F2)
            Active Apparent Power: 52.83 VA
            20170422-10:55:10.077683: sdm120c(22731) 1/1. Register Address 30025 [0018]
            20170422-10:55:10.146374: sdm120c(22731) Read time: 68623us
            20170422-10:55:10.146435: sdm120c(22731) reg[0/1]=16900 (0x4204)
            20170422-10:55:10.146490: sdm120c(22731) reg[1/1]=20972 (0x51EC)
            Reactive Apparent Power: 33.08 VAR
            20170422-10:55:10.146574: sdm120c(22731) 1/1. Register Address 30031 [001E]
            20170422-10:55:10.210248: sdm120c(22731) Read time: 63611us
            20170422-10:55:10.210303: sdm120c(22731) reg[0/1]=16213 (0x3F55)
            20170422-10:55:10.210353: sdm120c(22731) reg[1/1]=45397 (0xB155)
            Power Factor: 0.83
            20170422-10:55:10.210442: sdm120c(22731) 1/1. Register Address 30037 [0024]
            20170422-10:55:10.262878: sdm120c(22731) Read time: 52379us
            20170422-10:55:10.262934: sdm120c(22731) reg[0/1]=0 (0x0)
            20170422-10:55:10.262986: sdm120c(22731) reg[1/1]=0 (0x0)
            20170422-10:55:10.263056: sdm120c(22731) 1/1. Register Address 30071 [0046]
            20170422-10:55:10.316756: sdm120c(22731) Read time: 53643us
            20170422-10:55:10.316814: sdm120c(22731) reg[0/1]=16968 (0x4248)
            20170422-10:55:10.316866: sdm120c(22731) reg[1/1]=0 (0x0)
            Frequency: 50.00 Hz
            20170422-10:55:10.316942: sdm120c(22731) 1/1. Register Address 30073 [0048]
            20170422-10:55:10.374403: sdm120c(22731) Read time: 57397us
            20170422-10:55:10.374465: sdm120c(22731) reg[0/1]=17745 (0x4551)
            20170422-10:55:10.374515: sdm120c(22731) reg[1/1]=30597 (0x7785)
            Import Active Energy: 3351470 Wh
            20170422-10:55:10.374585: sdm120c(22731) 1/1. Register Address 30075 [004A]
            20170422-10:55:10.424519: sdm120c(22731) Read time: 49880us
            20170422-10:55:10.424575: sdm120c(22731) reg[0/1]=0 (0x0)
            20170422-10:55:10.424626: sdm120c(22731) reg[1/1]=0 (0x0)
            20170422-10:55:10.424695: sdm120c(22731) 1/1. Register Address 30343 [0156]
            20170422-10:55:10.475901: sdm120c(22731) Read time: 51152us
            20170422-10:55:10.475954: sdm120c(22731) reg[0/1]=17745 (0x4551)
            20170422-10:55:10.476004: sdm120c(22731) reg[1/1]=30597 (0x7785)
            Total Active Energy: 3351470 Wh
            20170422-10:55:10.476084: sdm120c(22731) 1/1. Register Address 30077 [004C]
            20170422-10:55:10.533541: sdm120c(22731) Read time: 57395us
            20170422-10:55:10.533602: sdm120c(22731) reg[0/1]=0 (0x0)
            20170422-10:55:10.533651: sdm120c(22731) reg[1/1]=0 (0x0)
            20170422-10:55:10.533721: sdm120c(22731) 1/1. Register Address 30079 [004E]
            20170422-10:55:10.583726: sdm120c(22731) Read time: 49927us
            20170422-10:55:10.583804: sdm120c(22731) reg[0/1]=0 (0x0)
            20170422-10:55:10.583855: sdm120c(22731) reg[1/1]=0 (0x0)
            20170422-10:55:10.583933: sdm120c(22731) 1/1. Register Address 30345 [0158]
            20170422-10:55:10.633801: sdm120c(22731) Read time: 49807us
            20170422-10:55:10.633858: sdm120c(22731) reg[0/1]=0 (0x0)
            20170422-10:55:10.633910: sdm120c(22731) reg[1/1]=0 (0x0)
            20170422-10:55:10.635085: sdm120c(22731) devLCKfile:
            20170422-10:55:10.635143: sdm120c(22731) devLCKfileNew:
            20170422-10:55:10.635199: sdm120c(22731) Clearing Serial Port Lock (22731)...
            20170422-10:55:10.635289: sdm120c(22731) Acquiring exclusive lock on /var/lock/LCK..ttyUSB0...
            20170422-10:55:10.635401: sdm120c(22731) Exclusive lock on /var/lock/LCK..ttyUSB0 acquired (0) Success...
            20170422-10:55:10.635584: sdm120c(22731) cmdLen=7
            20170422-10:55:10.635637: sdm120c(22731) cmdLen=7 COMMAND is not null
            20170422-10:55:10.635717: sdm120c(22731) errno=0, bRead=2 LckPID=22731 PID=22731 COMMAND='sdm120c'
            20170422-10:55:10.635781: sdm120c(22731) errno=0, bRead=2 LckPID=22731 PID=22752 COMMAND='sdm120c'
            20170422-10:55:10.635845: sdm120c(22731) errno=0, bWrite=14 PID=22752
            20170422-10:55:10.635907: sdm120c(22731) errno=0, bRead=-1 LckPID=22731 PID=0 COMMAND=''
            20170422-10:55:10.636154: sdm120c(22731) Clearing Serial Port Lock done
            OK
            • 20170422-10:46:42.533970: sdm120c(31757) ERROR (110) Connection timed out, 1/1, Address 30001 [0000]
              Ma che vuol dire?
              Gia in questa fase si può capire se l'adattatore fa il suo lavoro?
              E' un problema SW o HW?
              • Non saprei dirtelo prova con
                sdm120c -a 1 -b 9600 -P N -w 25 -d 1 /dev/ttyUSB0
                • Uguale
                  Inviato dal mio G7-L01 utilizzando Tapatalk
                    Vorrei contattate Gianfranco che ha scritto la libreria per capire cosa è questo ERROR(110). Che dici? sai come fare?
                    • scrivigli in PM anche se ultimamente risponde poco, però tentare non nuoce, di certo lui conosce la risposta.
                      • Anche io ho un problema del genere su un contatore,che pero' e' nuovo
                        Stesso errore, provero' a sostituirlo
                        Impianto 2,66 kWp - Power One 3.0 - 8 moduli Sunpower E20 333W - Raspberry con 123Solar@Walter62
                        https://www.dropbox.com/s/ag0k3azvne...rev04.pdf?dl=0 --> Guida Raspberry + Envir Cost con Measureit 118
                        • Usate sempre le opzioni
                          -w10 -z10 -j10
                          aggiustando i valori se necessario.
                          Monitoraggio energetico con Raspberry – 123Solar e MeterN
                          Monitoraggio energetico con Raspberry – Guida all’installazione e configurazione - IMPULSI
                          Monitoraggio energetico con Raspberry e contatori EASTRON SDM120modbus e/o SDM220modbus
                          • Sostituito SDM120C, risolto il problema della comunicazione
                            • Ok, voi siete già su Marte io in una grotta, ma devo pur iniziare... cosi subito mi sorge un dubbio.
                              Questo: sono cosi robusti questi SDM 230?
                              Si legge una tensione di 230 Volt, ma a casa mia può variare da 220 a 240 V.
                              Potete anche spiegarmi il perché i due SDM 230 vanno posti appena dopo il contatore, nel mio caso unico, di scambio ma prima del salvavita ecc..
                              • gli SDM 230 Modbus sono molto robusti resistono a correnti di 100A.
                                Si mettono prima del salvavita perché se c'è un corto circuito sono più protetti, dovrebbe scattare prima il salvavita
                                Per la tensione nessun problema, ne sopporta anche oltre 265V ( sperimentato)
                                Vincenzo per scaricare l'immagine di Flane, configurarla per il tuo uso e avviare il monitoraggio, impiegherai in totale 2/3 ore, non ti fare problemi di nessun genere
                                questo monitoraggio è il migliore che ci sia in circolazione e supercollaudato.
                                Materiale di primissima qualità.
                                • Va messo a monte dei carichi di casa ma a valle dell inverter
                                  • tu monitori con due contatori, quindi ne metterai uno subito dopo l'uscita dall'inverter e prima del differenziale dell'inverter e l'altro prima del differenziale di casa.
                                    • Si Dolam, forse mi faccio troppe pippe mentali, ma sono anche impegnato su altri "fronti" in particolare la moto tutta terreno, che dovrei mollare ma motociclisti si nasce...
                                      Non meno mi ha frenato l'intenzione di far rifare tutto il quadro elettrico, e una linea dedicata alla alimentazione delle PDC, ma ho sempre l'handicap dell'elettricista che lavora quando gli gira, indi continuo a perder tempo, per forza di cose mi dovrò arrangiare.
                                      Ora però, dato che non ci sono più i sensori TA, non dovrebbero esserci problemi di lunghezza collegamenti, per tanto dovrei poterli piazzare meglio questi contatori, salvo non ci siano problemi di distanza tra loro e il Raspberry, voglio dire: piazzarne uno appena dopo il contatore e l'altro appena dopo l'inverter è abbastanza facile, ma se il Raspberry lo piazzo vicino ad uno dei due l'altro per collegarlo ci potrebbero volere anche 1 o 2 metri di cavo, ci sono problemi in merito?
                                      Grazie.
                                      • Vince "Raspberry lo piazzo vicino ad uno dei due l'altro per collegarlo ci potrebbero volere anche 1 o 2 metri di cavo, ci sono problemi in merito?"
                                        nessun problema per la distanza, il mio contatore è a 25 metri dal raspberry ed uso un semplice cavo telefonico, cosiddetto doppino e funziona tutto perfettamente.
                                        in altri thread c'è chi invia i dati del contatoreal raspberry in wireless, tramite i SonOff modificati, ma questo è un campo per me vietato,
                                        ma con il cavetto vai sereno ( non stai sereno, nota)
                                        • Buona la "nota"
                                          • Date una occhiata all'allegato per cortesia.
                                            La configurazione proposta sfrutta un solo adattatore USB-RS485 con due contatori, dato che di porte sul Raspberry ce ne sono 4, è obbligatoria questa configurazione?
                                            Devono per forza interloquire i due, oppure si fa anche con uno per contatore.
                                            Moduli — Postimage.io
                                            • si può fare uno per contatore ed è una soluzione che preferisco, ma Flane è riuscito a fare la configurazione con un solo adattatore , quindi entrambe funzionano bene.
                                              La connessione dei contatori è quella dello schema , uno o due adattatori non cambia nulla, fai come meglio ti va
                                              • Scusa/te se rompo, stavo pensando alle distanze...
                                                In funzione di quello che hai scritto riguardo la lunghezza del doppino, avendo agli opposti angoli del garage il router e l'ambaradan fotovoltaico, credo sia meglio avvicinare il più possibile il Raspberry al router e collegare i contatori con il doppino, voglio dire,piuttosto di posare una ventina di metri di cavo per LAN, meglio il doppino, cosa ne dici?
                                                Certo se si potesse collegare il Raspberry via WiFi sarebbe una manna.
                                                • Usate solo ed esclusivamente un DOPPINO RITORTO SE NON VOLETE AVERE PROBLEMI
                                                  • "piuttosto di posare una ventina di metri di cavo per LAN, meglio il doppino, cosa ne dici?"
                                                    Sicuramente si , concordo, meglio usare più cavo telefonico che LAN .
                                                    Flane raccomanda , giustamente, l'uso di un doppino ritorto ( facile da trovare ed economico) ma se non ce l'hai o non puoi reperirlo nell'immediato , prendi pure 25 metri di cavo telefonico 2+1 da Leroy Merlin per 5 euro,
                                                    a me funziona perfettamente, se poi non dovesse andare prendi il cavetto ritorto che è certamente più adatto .
                                                    Mi piace sempre tentare prima la via più economica e facile.
                                                    • A me invece piace non dover continuamente perdere tempo a rispondere a chi continua ad avere problemi di lettura dei contatori anche perché non usa un cavo adatto ....
                                                      Cavi per seriale RS485 e cavi LAN - 123Solar & MeterN Italian forum
                                                      • In casa ho un paio di extender wireless con porte LAN, TP-Link 300 Mbps AV 200 WiFi Starter Kit, ottima copertura, e proprio in garage ho il primo extender collegato al router e presa di corrente, se ne acquisto un altro ci posso collegare il Raspberry senza girare per il garage con dei cavi, cosi posso mettere il tutto in una sola scatola elettrica... funziona?
                                                        • Vincenzo ho 4 TP-Link 300 Mbps AV 200 WiFi Starter Kit ( amazon), 3 direttamente connessi a raspberry e l'altro ad un router/accespoint, tutti perfettamente funzionanti.
                                                          Puoi metterne a cascata quanti ne vuoi, ricorda solo che ognuno va accoppiato all'ultimo della serie , quindi il 2 all'1, il 3 al 2, il 4 al 3, il 5 al 4 e così via
                                                          • Semplicemente usa uno Switch tre porte collegato al Powerline che hai già.
                                                            Curiosità: qual'è la distanza tra casa e garage?
                                                            Inviato dal mio EVA-L09 utilizzando Tapatalk
                                                            Nuovo sito che incoraggia la produzione e la vendita del biodiesel in italia
                                                            Eccolo qua!
                                                            Perche biodiesel?
                                                            La titolazione
                                                            • Tony "Semplicemente usa uno Switch tre porte collegato al Powerline che hai già."
                                                              ciao mi indichi quello che usi?
                                                              perché ne ho acquistato uno che non mi funziona e sarebbe una buona soluzione anche per me.
                                                              La distanza dal mio contatore al raspberry è di 25 metri, cavetto telefonico , due contatori (ora uno solo) uso una resistenza terminale.
