"Oilys" Bio- Clearing powder
Quantity can vary . As a guide use about 1 to 2 kg per 100 ltr.
After draining the Glyc from the Bio reaction tank TRANSFER the
Bio to another tank, reheat the bio to 45-50 deg c.
Turn on the mixer to agitate it.
Slowly add powder, Wear appropriate
Dust mask when doing this!!!.
leave the mixer on for 30 to 45 min then leave to settle overnight.
The next day, pump the Bio into a storage container or your car but leave about 8-10 ltr of Bio in the bottom of the tank, this is to mix with the sludge for easy removal .
To remove the sludge from the bottom of the tank mix the sludge and bio with a stick or stirrer so that it will all mix together then open the valve to drain the contents, stir whilst draining.
What is collected in the drum is left standing overnight to settle and the clear bio is then drained of the top. The sludge can be disposed of and the bio used. There is no need to clean container as any paste left will not contaminate the next mix.
Caution----- keep moisture away from powder before use. Best if stored in airtight container
