Salve,
bazzicando per internet ho trovato quest'articolo che forse potrebbe essere legato al discorso FF.
Secondo l'articolo, una molecola immersa in un liquido e riscaldata ad altissime temperature assume un moto rotatorio (spin) sul suo asse cosi' elevato da allontanare qualsiasi altra molecola gli stia vicino. In queste condizioni sarebbe in grado di muoversi senza attriti. Ecco il passaggio in inglese di cui parlo...
CITAZIONE
They found an example of molecular motion in a chemical reaction that actually destroys friction. This superfast molecule, which makes a whopping 270 trillion rotations per minute, literally pushes away molecules that surround it in solvent, wiping out most of the resulting frictional force.
poi continua...
CITAZIONE
The team made a solution of iodine cyanide and water, sent drops of it streaming down a wire, then hit the drops with pulses from an ultraviolet laser. The laser shattered some molecules in the solution. One resulting bit was a two-atom cyanide radical. It was intensely hot – 4,700 degrees Kelvin, about three-quarters of the temperature at sun’s surface – and started a superfast spin.
CITAZIONE
The Brown-USC team plans further tests to see if the friction-free phenomenon applies to different molecules in different solutions. If it does, Stratt said chemists might need to rethink the pathways molecules use to move energy.
Il link e':
http://www.brown.edu/Administration/News_B...-06/05-101.html
Bhe se ho tradotto bene questo strano comportamento (se confermato) potrebbe essere interessante....vedro' di reperire altre info.
Trovati altri links che riguardano questa notizia...
http://www.usc.edu/uscnews/stories/12246.html
http://www.nsf.gov/news/news_summ.jsp?cntn_id=106830&org=NSF
http://www.usc.edu/schools/college/faculty...lty1003126.html
