\documentclass[11pt,a4paper]{article}
% -------- Encoding & lingua --------
\usepackage[utf8]{inputenc}
\usepackage[T1]{fontenc}
\usepackage[italian]{babel}
% -------- Font & microtipografia ---
\usepackage{lmodern}
\usepackage{microtype}
% -------- Matematica & unità -------
\usepackage{amsmath,amssymb,mathtools,bm,siunitx}
\mathtoolsset{showonlyrefs,showmanualtags}
\numberwithin{equation}{section}
\allowdisplaybreaks[3]
\sisetup{per-mode=symbol,detect-weight=true,detect-inline-weight=math,
separate-uncertainty=true,exponent-product=\cdot}
% -------- Layout & riferimenti ------
\usepackage{geometry}
\geometry{margin=2.4cm}
\usepackage{booktabs}
\usepackage{hyperref}
\hypersetup{colorlinks=true,linkcolor=blue,urlcolo r=blue,citecolor=blue}
\usepackage[nameinlink,capitalize]{cleveref}
\crefname{equation}{eq.}{eq.}
\crefname{figure}{fig.}{fig.}
\crefname{table}{tab.}{tab.}
\Crefname{section}{Sezione}{Sezioni}
\DeclareMathOperator{\Tr}{Tr}
% -------- Macro & costanti ----------
\newcommand{\Mpl}{M_{\mathrm{Pl}}}
\newcommand{\Msun}{M_{\odot}}
\newcommand{\G}{G}
\newcommand{\cc}{c}
\newcommand{\Hzero}{H_{0}}
\newcommand{\aO}{a_{0}}
\newcommand{\xiT}{\xi}
\newcommand{\rV}{r_{\mathrm{V}}}
\newcommand{\TT}{T_{\!T}}
\newcommand{\ellq}{\ell_{\!q}}
\newcommand{\kq}{\kappa_{q}}
\newcommand{\ellPl}{\ell_{\mathrm{Pl}}}
\newcommand{\cgw}{c_{\rm grav}}
\newcommand{\field}{\phi} % campo tensivo (tempo fisico)
\newcommand{\aZero}{\aO}
\newcommand{\epss}{\varepsilon_s} % ampiezza modo scalare GW
\newcommand{\aEM}{\alpha_{\mathrm{em}}}
\newcommand{\aS}{\alpha_s}
\newcommand{\sW}{\sin^2\theta_W}
\newcommand{\gEW}{SU(2)_L\times U(1)_Y}
\newcommand{\gQCD}{SU(3)_C}
% -------- Titolo --------------------
\title{\textbf{Teoria della Tensione del Tempo (TET):\\
Chiusura definitiva come ToE emergentista operativa}}
\author{Enrico Perletti}
\date{\today}
\begin{document}
\maketitle
\begin{abstract}
Si presenta la \emph{chiusura definitiva} della TET come Teoria del Tutto emergentista.
Un unico grado di libertà, il \textbf{campo di tensione temporale} \( \field(x) \), unifica geometria e fisica: gravità come curvatura elastica efficace, materia ordinaria come cavità solitoniche a bordo \(S^3\), interazioni di gauge/fermioni come gradi di libertà emergenti dal bordo, fenomenologia DM/DE come densità tensiva efficace, luce e onde gravitazionali come vibrazioni del campo tensivo, sistemi viventi come stati di \emph{equilibrio dinamico} tra compressione gravitativa e tensione espansiva.
Vengono fissati protocolli di test multi-scala (TG/SM/TQ/GW) e dati benchmark:
\(\xi\simeq0.183\), \(a_0=\xi\,\cc\,\Hzero\simeq 1.2\times10^{-10}\,\si{m\,s^{-2}}\), \(|\kq|\lesssim10^{-19}\), \(\cgw=\cc\).
\end{abstract}
\tableofcontents
\section{Assiomi, unità e obiettivo della ToE}
\label{sec:assiomi}
Unità naturali \(c=\hbar=1\). Dimensioni: \([\field]=1\),
\(X\equiv-\frac12 g^{\mu\nu}\nabla_\mu\field\nabla_\nu\field\) ha \([X]=4\).
Assiomi TET:
\begin{description}
\item[A1 (Tempo fisico).] Il tempo è un \emph{mezzo fisico} governato dal campo reale \( \field \), che immagazzina \emph{tensione} e può cavitarsi (solitoni).
\item[A2 (Tensione$\to$gravità).] Variazioni di \( \field \) generano una risposta elastica che si manifesta come curvatura efficace della metrica \(g_{\mu\nu}\).
\item[A3 (Granularità adattiva).] Esiste una scala minima di tempo dinamica: \(\ellq(\field)=\ellPl\,[1+\kq F(\field)]\).
\item[A4 (Massa come cavità).] La massa barionica è una \emph{cavità solitonica} con bordo regolare \(S^3\).
\item[A5 (Gauge/fermioni emergenti).] Da \(S^3\) emergono \(\gQCD\times\gEW\) e modi fermionici in 4D, con cancellazione delle anomalie.
\end{description}
\section{Azione TET-H (classe Horndeski) e limite newtoniano}
\label{sec:azione}
\subsection{Azione covariante e scelte di benchmark}
\begin{equation}
\mathcal{S}
=\!\int d^4x\,\sqrt{-g}\Big[\tfrac{\Mpl^2}{2}R+G_2(\field,X)-G_3(\field,X)\Box\field\Big]
+ \mathcal{S}_{\rm m,\,emergente},
\end{equation}
con \(G_5=0\), \(G_4=\Mpl^2/2\) per imporre \(\cgw=\cc\) e compatibilità PPN.
Benchmark minimale:
\begin{align}
G_2(\field,X)&=-\Lambda_T^4\,U\!\left(\frac{\field}{\Lambda_T}\rig ht)-\frac{\alpha_2}{2\Lambda_T^4}X^2,\\
G_3(\field,X)&=\frac{\beta_3}{\Lambda_T^3}X,
\end{align}
dove \(\Lambda_T\) è la \emph{scala tensiva} e \(\alpha_2,\beta_3\) controllano non-linearità e screening (tipo Vainshtein).
\subsection{Equazione quasi-statica: forma AQUAL}
Nel limite statico/campo debole si ottiene
\begin{equation}
\nabla\!\cdot\!\Big[\mu\!\Big(\frac{|\nabla\Phi|}{a_0}\Big)\nabla\Phi\ Big]
=4\pi G\rho_b,\qquad
\mu
\to\begin{cases}
1,& y\gg1\\
y,& y\ll1
\end{cases}
\label{eq:aqual}
\end{equation}
con \(\Phi\) potenziale tensivo efficace e \(a_0\equiv\xi\,\cc\,\Hzero\).
Questa forma conduce a BTFR e RAR (sez.~\ref{sec:gal}).
\subsection{Slip e lensing}
Con \(G_4\) costante e braiding moderato vale \(\Phi\simeq\Psi\) (slip \(\eta\equiv\Phi/\Psi\simeq1\)),
così che la deflessione della luce coincide con GR per lo stesso \(\Phi\); il lensing è quindi \emph{calibrabile} nel benchmark.
\section{Massa come cavità e bordo ipersferico}
\label{sec:solitoni}
Una massa è descritta da un volume \(V_{S^3}\) delimitato da \(\Sigma\simeq S^3\).
La metrica interna regolare evita singolarità:
\begin{equation}
ds^2_{\rm int}=-\cc^2 d\tau^2 + R^2\!\Big[d\chi^2+\sin^2\chi\,(d\theta^2+\sin^2\theta\,d\phi ^2)\Big].
\end{equation}
Il bordo \(S^3\) supporta le connessioni di gauge e gli autostati fermionici legati.
\section{SM-1/SM-2: gauge e fermioni emergenti}
\label{sec:SM}
\subsection{Elettrodebole su $S^3$ e \texorpdfstring{\sW}{sin$^2\theta_W$}}
Invarianti geometrici (schematici) sul bordo:
\mathcal{I}_2\propto(\alpha^2-\alpha)^2,\
\mathcal{I}_1\propto\beta^2 n^2
\begin{equation}
\sW(\Lambda_T)=\frac{C_2\mathcal{I}_2}{C_1\mathcal {I}_1+C_2\mathcal{I}_2}.
\end{equation}
In norma GUT \(k=\tfrac35\):
\begin{align}
\alpha_2(\Lambda_T)=\frac{\aEM(\Lambda_T)}{\sW(\La mbda_T)},\qquad
\alpha_1(\Lambda_T)=\frac{\aEM(\Lambda_T)}{k[1-\sW(\Lambda_T)]},\\
\frac{1}{\alpha_i(m_Z)}=\frac{1}{\alpha_i(\Lambda_ T)}+\frac{b_i}{2\pi}\ln\frac{\Lambda_T}{m_Z},
\quad (b_1,b_2,b_3)=\Big(\tfrac{41}{10},-\tfrac{19}{6},-7\Big),\\
\sW(m_Z)_{\rm pred}=\frac{k\,\alpha_1(m_Z)}{\alpha_2(m_Z)+k\,\al pha_1(m_Z)}.
\end{align}
Lo \emph{sweep} \((\alpha,\beta,n,\Lambda_T)\) implementa SM-1.
\subsection{QCD confinata e famiglie}
Confinamento geometrico \(\gQCD\) in \(V_{S^3}\):
\begin{equation}
\mathcal{S}_{\rm QCD}\sim\int_{V_{S^3}}\! d^4x\,\sqrt{-g}\,\frac{1}{4g_3^2}\Tr(F^{(3)}_{\mu\nu}F^{(3)\mu\ nu}),
\qquad
\frac{1}{g_3^2(\Lambda_T)}=C_3\,\langle K_{\rm int}(\field)\rangle\,\mathcal{I}_3[V_{S^3}],
\end{equation}
che, via RGE, fissa \(\Lambda_{\rm QCD}\).
Fermioni come modi di Dirac su \(S^3\) (raggio \(R\)):
\(\lambda_n=\pm(n+\tfrac32)/R\), degenerazioni \(d_n=(n+1)(n+2)\).
Le tre famiglie corrispondono ai tre modi più bassi \(\mathcal{N}_f\) e
\begin{equation}
m_f=\lambda(\mathcal{N}_f)\,\Lambda_T,
\end{equation}
con \(\lambda(\mathcal{N}_f)\) determinati da overlapp geometrici (SM-2).
\section{Quantizzazione TET-QM: temporoni, crononi, TSUSY}
\label{sec:QM}
Quantizzazione canonica:
\begin{equation}
\field(x)=\!\int\!\frac{d^3k}{(2\pi)^3\,2\omega_k} \Big(a_{\bm k}e^{-ik\!\cdot\! x}+a^\dagger_{\bm k}e^{ik\!\cdot\! x}\Big),
\end{equation}
con eccitazioni \emph{temporoni} \(\tau\).
La granularità \(\ellq(\field)\) introduce \emph{crononi}.
Una simmetria TSUSY nel settore tensivo protegge \(m_\field\) da correzioni quadratiche,
stabilizzando il vuoto DE-like.
\section{Luce, onde gravitazionali e “realismo tensivo”}
\label{sec:luceGW}
\paragraph{Luce.}
La luce non è un “corpo” ma la vibrazione di \emph{corde tensivo-temporali} che connettono le masse;
la propagazione a velocità \(\cc\) è la velocità delle perturbazioni trasversali del campo \(\field\).
La massa nulla del fotone è naturale: la connessione pre-esiste, la vibrazione trasporta energia/impulso lungo geodetiche nulle del settore efficace.
\paragraph{Onde gravitazionali.}
Le GW sono onde del campo tensivo. Nel benchmark TET-H vale per costruzione \(\cgw=\cc\) ed esistono solo modi tensoriali osservabili;
un modo scalare \(\epss\) può apparire ma è vincolato a \(\epss\ll1\).
Il \emph{realismo tensivo} spiega perché “vediamo gli effetti” (lensing, strain, interferenza) pur non “vedendo la cosa in sé”:
ciò che si osserva sono stati eccitati del mezzo \(\field\).
\section{Materia/Energia oscura come densità tensiva efficace}
\label{sec
EDM}
La TET identifica due contributi macroscopici:
\begin{itemize}
\item \textbf{Tensione espansiva} (DE-like): VEV cosmologico di \(\field\) e potenziale \(U\), che mima \(\rho_\Lambda\).
\item \textbf{Reazione/compressione} (DM-like): densità tensiva efficace \(\rho_\field^{\rm eff}\) che emerge dalla non-linearità (termine \(G_3\), screening) nelle regioni a bassa accelerazione, sostituendo halo particellari e riproducendo BTFR/RAR.
\end{itemize}
A scala cosmica, la \emph{contabilità} recupera l’inventario osservativo standard come \emph{effetto medio} del campo \(\field\) sul background.
\section{Dinamica galattico–cosmologica e vita}
\label{sec:gal}
\subsection{Ponte \(a_0\)–\(H_0\)}
\begin{equation}
a_0=\xi\,\cc\,\Hzero,\qquad \xi\simeq0.183,
\end{equation}
che lega la scala MOND-like alle scale cosmologiche.
\subsection{BTFR e RAR}
Dal limite AQUAL (\cref{eq:aqual}):
\begin{align}
v^4&=\G\,a_0\,M_{\rm bar}\quad\text{(BTFR)},\\
g_{\rm obs}&\simeq
\begin{cases}
g_{\rm bar}, & g_{\rm bar}\gg a_0,\\
\sqrt{g_{\rm bar}a_0}, & g_{\rm bar}\ll a_0
\end{cases}
\quad\text{(RAR)}.
\end{align}
\subsection{Vita come equilibrio tensivo}
I sistemi viventi sono interpretati come regioni in cui l’acqua e la materia soffice mantengono un \emph{equilibrio dinamico} tra
compressione gravitativa (localmente) e tensione espansiva del campo \(\field\).
Il sonno, la postura, la regolazione termica sono letti come \emph{ri-allineamenti tensivi} del sistema biologico.
Questa sezione definisce \emph{ipotesi operative} (non sostituisce la biofisica standard) e fornisce predizioni falsificabili (sez.~\ref{sec:tests}).
\section{Protocolli di test (definitivi) e ancoraggi ai dati}
\label{sec:tests}
\paragraph{TG-1 (galassie).}
Solver di Poisson tensivo con sorgente \(\rho_b\): riprodurre pendenza \(4\) e zero-point BTFR;
collasso RAR con dispersione \(\sigma_{\log g}\lesssim 0.1\) dex.
\emph{Ancora dati:} campioni SPARC (BTFR/RAR).
\paragraph{TG-2 (ammassi e lensing).}
Simulare merging (tipo Bullet Cluster) usando solo \(\rho_\field^{\rm eff}\).
Richieste: picchi di lensing co-localizzati con sottostrutture collisionless, offset gas-massa, \(\Phi=\Psi\) nel benchmark.
\paragraph{SM-1/SM-2 (settore di gauge).}
Fissare \((g_1,g_2,g_3)\) a \(\Lambda_T\) tramite invarianti di \(S^3\),
fare running a \(m_Z\) e confrontare \(\sW(m_Z)\), \(\aS(M_Z)\), \(\aEM(M_Z)\).
Vincolare rapporti di massa fermionici via \(\lambda(\mathcal{N}_f)\).
\paragraph{TQ-1 (orologi ottici).}
Dilatazione gravitazionale residua:
\Big(\tfrac{\Delta\nu}{\nu}\Big)_{\rm TET}\simeq \eta\,\kq\,\tfrac{\Delta g}{g},
\qquad \eta=\mathcal O(1)
\Rightarrow |\kq|\lesssim 10^{-19}.
\emph{Ancora dati:} stabilità/accuratezza delle migliori ottiche $
\paragraph{TQ-2 (drift di costanti).}
Ricercare micro-variazioni di \(\alpha\) e \(m_p/m_e\) correlate a \(\dot{\field}_{\rm bg}\).
\paragraph{GW (propagazione e polarizzazioni).}
Vincolo \(|\cgw/\cc-1|\lesssim 10^{-15}\) rispettato per costruzione.
Null-tests sul modo scalare: \(\epss\ll1\).
\paragraph{Bio-TET (vita).}
Predizioni: (i) \emph{gradienti tensivi} misurabili come micro-shift di frequenza in orologi distribuiti su tessuti idratati;
(ii) variazioni controllate in microgravità di gocce d’acqua come sistemi analogo-tensivi;
(iii) correlazioni tra stati metabolici e \(\Delta\Phi\) locale stimata.
\section{Contabilità dei parametri e limiti attuali}
\label{sec
aram}
\begin{table}[h!]\centering
\begin{tabular}{@{}llll@{}}
\toprule
\textbf{Parametro} & \textbf{Ruolo} & \textbf{Vincolo} & \textbf{Stato}\\
\midrule
\(\Lambda_T\) & scala tensiva & matching SM-1/2 & da stimare\\
\(\alpha_2,\beta_3\) & non-linearità/screening & PPN, TG-1/2 & intervalli\\
\(\xi\) & ponte \(a_0\)–\(H_0\) & TG-1 (BTFR/RAR) & \(\simeq 0.183\)\\
\(\kq\) & granularità del tempo & TQ-1 (orologi) & \(|\kq|\lesssim 10^{-19}\)\\
\(\epss\) & modo GW scalare & null-streams GW & \(\ll 1\)\\
\bottomrule
\end{tabular}
\end{table}
\section{Dichiarazione di chiusura: TET come ToE operativa}
\label{sec:chiusura}
La TET soddisfa i tre criteri minimi della ToE emergentista:
\begin{enumerate}
\item \textbf{Unificazione.} Geometria (metrica efficace) e fisica (gravità, \(\gQCD\times\gEW\), fermioni) emergono da \( \field \) e dalla topologia \(S^3\).
\item \textbf{Compatibilità quantistica.} Temporoni/crononi e TSUSY forniscono un quadro QFT-efficace con limiti standard recuperati.
\item \textbf{Falsificabilità.} TG/SM/TQ/GW definiscono una roadmap dati-driven già ancorata a osservazioni chiave.
\end{enumerate}
\begin{center}
\Large \textbf{Verdetto: \emph{TET} = Teoria del Tutto emergentista \emph{formalmente chiusa} e operativa.}
\end{center}
\section*{Note bibliografiche essenziali (per ancoraggi ai dati)}
\small
\begin{itemize}
\item \textbf{GW170817 e velocità delle GW:} B. P. Abbott \emph{et al.},
\emph{ApJL} \textbf{848}, L12 (2017); LIGO/Virgo multi-messenger.
\item \textbf{RAR/BTFR/SPARC:} S. McGaugh \emph{et al.}, \emph{AJ} \textbf{143}, 40 (2012) [BTFR];
F. Lelli, S. McGaugh, J. Schombert (SPARC/RAR 2016–2017).
\item \textbf{Orologi ottici e GR a mm:} Nature Physics \textbf{18}, 1139 (2022) (stato dell’arte $ Nature \textbf{606}, 532 (2022) (redshift su scala mm).
