ecco la notizia di oggi.<br><br><a href="http://www.prenergypower.com" target="_blank">www.prenergypower.com</a><br><br>autorizzato il progetto<br>PORT TALBOT UK<br><br><a href="http://WWW.ALERION.IT" target="_blank">WWW.ALERION.IT</a><br><br><br>BUILDING WORK TO START ON £400M PLANT IN SUMMER<br>Be the first reader to comment on this story<br><br>09:00 - 22 November 2007<br><br>The company behind the power station says it expects work to start next summer, ready for it to open in 2010.Prenergy says 400 construction and 150 permanent jobs will be created, and promises a green operation worth millions of pounds to the local economy.<br><br>Director Matthew Carse said: "This is a groundbreaking step, not only for Port Talbot but for environmentally friendly power generation in the UK."<br><br>Prenergy says the annual payroll once the £400 million plant is up and running will amount to £7.5 million a year, and will boost the local economy further with around £8 to £10 million worth of local maintenance contracts.<br><br>Generating 2.3 terawatt hours of renewable energy per year, the plant will provide enough electricity for half the homes in Wales and deliver 70 per cent of the Welsh renewable energy target for 2010.<br><br>Sustainable wood chip fuel will be brought to the plant directly by sea using the deepwater harbour.<br><br>Prenergy says the power station is designed to achieve energy efficiencies of around 36 per cent, compared to the typical 22 per cent levels of smaller plants.<br><br>Mr Carse added: "Using wood chip from independently certified sustainable forestry, which ensures harvested trees are replanted, means generation is carbon-neutral and sustainable."<br><br><span style="color:red">***<br>MODERAZIONE: Cortesemente, la prossima volta inserisci articoli scritti in lingua italiana per consentire a tutti di capire il contenuto. In alternativa avresti potuto inserire una breve sintesi.<br>Grazie<br>Leptone<br>*** </span><br><br><br>(INCORCIAMO CON QUESTA DI 2006/MAGGIO) Alerion Energie Rinnovabili acquista il 50% di EWF ed investe anche nell'eolico<br><br>Alerion, attraverso la controllata Alerion Energie Rinnovabili, è entrata in joint venture con un primario operatore nella logistica e nella commercializzazione di legname a livello mondiale, rilevando il 50% della società Energy Wood Factory ("EWF"
. EFW, in cui Alerion ha in questa fase apportato 2 milioni di Euro, intende sviluppare una significativa capacità di generazione elettrica alimentata a biomasse, ubicata in Italia e all’estero.<br><br>In particolare, EWF ha stipulato un accordo per l’acquisto del 100% della società Prenergy Power Ltd, la quale sta sviluppando un progetto finalizzato alla realizzazione di una centrale termoelettrica da 300 MW nel porto di Talbot in Galles (UK), alimentata a legname. L’energia elettrica prodotta sarebbe destinata al mercato libero ovvero, in base a contatti avanzati, verrebbe interamente ceduta a primari operatori inglesi con contratti di durata quindicennale. In base a stime preliminari, l’investimento complessivo per la realizzazione dell’impianto dovrebbe essere pari a circa 300 milioni di Euro e rimane, tra l’altro, subordinato al completamento dell’iter autorizzativo, previsto entro la fine del 2006. Prenergy ha di recente ottenuto l’autorizzazione di "operatore elettrico" nel Regno Unito; si segnala che nel Regno Unito la produzione di energia elettrica da fonti rinnovabili è incentivata attraverso il riconoscimento di strumenti paragonabili ai certificati verdi italiani.<br><br>EWF ha altresì allo studio l’integrazione a monte al fine di collegare la capacità di generazione elettrica con un sistema correlato di approvvigionamento e controllo della materia prima ("fabbrica del legno"
.<br><br><span class="edit">Edited by leptone - 23/11/2007, 11:39</span>
