Vagando tra le pale ho trovato questo interessante link ...
Efficient design of wind turbine blades requires solving several equations involving the lift coefficient and angle of attack for the airfoil of interest. This software allows you to specify the number of blades, required TSR, approx efficiency of blades, the blade radius and wind speed. The program will design a set of blades that will meet your specifications, it will provide you with calculated power output, torque and rotational speed to match your generator. Acknowledgment to Claus Nybroe for formulae
http://warlock.com.au/bladecalc.htm
... con beneficio di inventario ... non l'ho testato
