<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CAugusto%5CIMPOST%7E1%5CTemp%5Cms ohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>14</w:HyphenationZone> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:595.3pt 841.9pt; margin:70.85pt 2.0cm 2.0cm 2.0cm; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabella normale"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Considerato che su questo forum leggo spesso che non si può collegare una caldaia a gas metano ed una termostufa ,ciò possibile solo separando i flussi termici, e qualora la potenza eguale o superiore a 35 kw necessita di centrale termica ,sistema antincendio…ecc…ecc…Mi chiedo se ho la caldaia a metano fuori al balcone e la idrostufa in casa, ditemi innanzi tutto a che serve la centrale termica per uno solo generatore di calore e dove la dovrei fare…forse in salotto o sul balcone?
Premesso che io sono dell’idea che qualora i generatori sono installati in locali diversi non c’è bisogno di nessuna centrale e di nessuna pratica i.s.p.e.l.s.
Dal momento che mi interessa sapere con certezza se è possibile fare detto impianto gradire conoscere,dal momento che non sono riuscito a trovare la normativa completa,dove posso reperire detta normativa e gradirei anche conoscere le sanzioni previste per chi , non si attiene a quanto eventualmente previsto.Se qualcuno mi può postare quanto richiesto grazie infinite
