Inverter con efficenza minore del previsto. - EnergeticAmbiente.it
  • Inverter con efficenza minore del previsto.
    Ciao a tutti, chiedo un parere ai superesperti, ho collegato da Gennaio l'impianto in firma :
    Impianto: totalmente integrato 5.61 kw
    51 pannelli Avancis film sottile 110
    3 inverter Mastervolt XS2000
    Esposizione: 15 pannelli -83 est + 36 pannelli +97 ovest Tilt 16.5°
    Praticamente ho 3 inverter separati, uno collegato a 15 pannelli a film sottile orientati ad Est e due ad ovest ognuno con 18 pannelli.
    Gli inverter sono dei MasterVolt Sunmaster XS2000 con trasformatore.
    Qui potete trovare le caratteristiche : http://www.mastervolt.it/solare/prodotti/sunmaster-xs/sunmaster-xs2000/
    Specifiche generali
    Operating voltage range100-450 V
    Maximum input power1670 Watt (W)
    Maximum input voltage450 V
    Galvanic Isolationclass II (safety transformer)
    MPP efficiency (Fraunhofer algortithm)99,9 %
    Number of MPP trackers1
    Number of solar inputs2 string connections each are connected in parallel
    Maximum efficiency95.7 %
    Safety devices DC sideisolation resistance monitoring • overvoltage detection • inverse polarity protection • curren
    Safety devices AC sidecurrent limitation • DC injection protection • short circuit protection (ceramic fuse) • over-
    User interfaceintegrated LCD - display with backlight, 4 buttons and bright diagnostic LED. All relevant AC and DC
    Dimensions (HxWxD)545x356x145 mm
    Weight10 kg
    Product warranty5 year
    Safety classclass I (metal housing with earth connection)
    Specifiche tecniche
    AC Connection2.5 - 4 mm² terminal block
    Maximum output power1575 Watt (W)
    Power factor control> 0.99
    Recommended PV power range1300-2000 Watt peak (Wp)
    Solar input connector2 sets of MultiContact (4 mm) connectors
    Grid voltage230 - AC single phase (184 - 265 V, country dependent) V
    Nominal output power (@45ºC)1500 Watt (W)
    Nominal output current8 A
    Output frequency range45-65 Hz, country dependent
    Power consumption (Standby power)< 0.5 Watt (W)
    European efficiency94.4( at 300 V) %
    Nominal input power1590 Watt (W)
    Start-up power5 Watt (W)
    MPP voltage range at nom. Power145-360 V
    Rated input current11 A
    Fuseinternal PCB fuse
    External communication2 surge protected RS485 connections. 2 Masterbus connections. Max. 20 XS units can be connected to 1
    Electrical safetyEN 60950-1
    National grid interface req.VDE 0126-1-1 / DK5940 / RD1663-2000 / K SC 8536 / G83-1 compliant
    LV directive2006/95/EC
    ImmunityEN 55024; EN 61000-4-2 and -3; EN 61000-4-4, -4-5 and -4-6
    Island protectionredundant voltage and frequency window monitoring. Independent cut-off by means of 2-pole relay and
    Temperature protectionthermal switch-off at internal over temperature
    DC current injectionVDE0126-1-1 / DK5940 / G83 / KSC8536 compliant
    EmissionEN 55022, class B
    HarmonicsEN 61000-3-2
    Dips, variations and flickerEN 61000-4-11 and -3-3
    Harmonic distortion< 3% at full power
    EMC directive89/336/EEC
    Approval CEyes
    Maximum relative humidity (Non condensing)95%
    Specifiche ambientali
    Protection degree(IP)44
    Temperature range(to specifications)-20 tp 45 °C
    Temperature range(operating)-20 to 60 °C
    Relative humidityMaximum 95% (non condensing) PCB has anti-moisture coating
    In particolare mi interessa il dato seguente :
    Che ho interpretato come l' efficenza globale degli inverter tra Potenza immessa in DC e resa in AC, mi potevo aspettare qualche piccola oscillazione, ma ad oggi dopo 2 mesi e mezzo vedo che la potenza in uscita in AC è circa l' 88/89% di quella in DC. dando per buoni i dati del display che comunque come verificato con multimetri e pinze amperometriche sono molto simili praticamente coincidenti a quelli reali.
    Ritenete normale questa discrepanza con il dichiarato ?
    E se non lo fosse dove posso cercare l' origine di questo basso rendimento ?
    I produttori possono risponderne in qualche modo ?
    Esperienze simili con questi inverter che comunque costruttivamente sembrano fatti molto bene ?
    Cosa fare ?
    Grazie a tutti.
    SuperMario
    Impianto: totalmente integrato 5.6 kw
    I moduli sono questi: http://www.avancis.de/en/products/at...chash=6da5645a ?
    Manca l'indicazione della composizione delle stringhe. Immagino 5+5+5, 6+6+6. Ma saresti ben sotto i 300 Vmp in STC.
      Si, corretti sia i moduli che le composizioni delle stringhe.
      Cosa ne pensi ?
        Toninon, per tua esperienza come varia il rendimento ai diversi valori di Vmp ? (poi il 300 indicato è STC o NOCT ?)
        E' una eresia collegare due stringhe sbilanciate da 7+8 panneli a Est e poi 2 da 9 sugli inverter a Ovest ? Alzando il Vmp pensi migliorerei l'efficenza?
        Sto cercando di capire come funziona il mio impianto.
        Grazie mille
          [QUOTE=SuperMarioCar;119200159]
          NO NON E' UNA ERESIA, PIU' PROBABILMENTE SONO 2 ERESIE.
          Non devi avere struinghe con numero di moduli diverso sullo stesso inverter e non ti suggerisco di andare oltre i 7 moduli per stringa.
          Tuttavia 5 moduli secondo me non è un buon dimensionamento e può giustificare la ridotta performance dell'inverter.
          cerco di chiarirti.
          a te interessa la tensione a Vuoto VOC alla più bassa temperatura del luogo di installazione prevedibile (io in Sicilia metto minimo -10° per sicurezza). Questo valore deve rimanere sotto i 450V per i tuoi inverter. E già 8 moduli è un pochino rischioso. Con 7 Non hai problemi invece.
          Il secondo dato che ti interessa è la Vmpp alla temperatura massima che prevedi possa essere raggiunta dal modulo (io in Sicilia metto 80°, magari al nord potrebbe bastare 70 o 75 per essere più prudente). Questo valore deve essere maggiore della tensione MPP minima e il più possibile vicino ai 300V del tuo inverter.
          Insomma devi trovare il miglior rapporto tra il numero di moduli per stringa in modo da avere la tensione MPP nell'intervallo di temperatura di lavoro dei moduli probabile (diciamo dai -10° agli 80°) ma senza superare alla temperatura minima con la Voc il massimo di tensione di sicurezza previsto dall'inverter (nel tuo caso 450V.)
          Ora il dimensionamento con le stringhe da 5 moduli sebbene nel range di lavoro ha una tensione MPP a 25° e con 1000W/Mq di circa 210V che sebbene nel range di lavoro del tuo inverter è abbastanza lontano dai 300V che rappresenta la migliore condizione di lavoro per l'inverter, anche perchè in condizioni di lavoro nei periodi migliori la temperatura dei moduli sarà più alta e l'irraggiamento non di 1000W e quindi in realtà lavorerai a valori di tensione abbastanza più bassi.
          Con 6 moduli arrivi sui 250V a 25° e 1000 di irraggiamento, infine con 7 Moduli arrivi a 290 ed è a questa configurazione che risulti più vicino ai 300V.
          Però devi verificare che alla temperatura minima non superi con la Voc i 450V. Con 7 moduli a 25° e con 1000W/Mq arrivi a circa 400V e hai un buon margine. Se invece mettessi 8 moduli arriveresti ai fatidici 450 e saresti veramente al limite del rischio di distruggere l'inverter. Per cui con 9 non se ne discute.
          spero di essere stato chiaro
          Nicola
            Grazie Nicola !!! Ora è più chiaro.
            L' impianto è concluso ed operativo da tempo, non posso fare variazioni, ed i 5x3 moduli era il massimo che potevo mettere li.
            Quindi temo di dovermi tenere tutto come è anche il basso rendimento, a meno di ipoteticamente cambiare inverter con una curva di rendimento più piatta al variare della tensione.
            Confermi ?
            Ciao e grazie
              sostanzialmente si. Forse era meglio fare 2X17=14 anzichè 15.
              Anche perchè col tempo i moduli in film degradano gradualmente le prestazioni di tensione massima per cui potrebbe andare peggio.
              Ma a quel punto potresti pensare di fare 2X14 e lasciare un modulo a "riposare" se edi che l'efficienza andasse sotto l'80% potrebbe convenire.
                Ho provato a guardare sul sito del produttore dell'inverter ma non ho trovato il grafico con l'andamento del rendimento in funzione di tensione e potenza (che molti produttori espongono).
                Quindi non posso dire se l'89 % e' un rendimento normale. Guardando i grafici di altri inverter direi che la differenza con il massimo e' troppa, prova ad interpellare il produttore.
                  Ho scritto al produttore, vediamo cosa dice.
                  A titolo d'esempio riporto quanto letto sui display oggi attorno alle
                  16.00 :
                  Inverter 1 3x5 pannelli
                  Tensione DC 192 V
                  Potenza DC 545 W
                  Potenza AC 489 W
                  Quindi efficienza 89.7%
                  Inverter 2 3x6 pannelli
                  Tensione DC 226 V
                  Potenza DC 1249 W
                  Potenza AC 1111 W
                  Quindi efficienza 88.9%
                  Inverter 3 3x6 pannelli
                  Tensione DC 234 V
                  Potenza DC 1282 W
                  Potenza AC 1135 W
                  Quindi efficienza 88.5%
