<b>Biodiesel fatto in casa</b> - parte prima
  • Autore discussione Autore discussione belinassu
  • Data d&#039;inizio Data d'inizio
Stato
nformation on making biodiesel may be found in specific websites :
http://www.biodiesel.org/
http://www.greenfuels.org/bioindex.html
http://www.webconx.com/making_biodiesel.htm
http://journeytoforever.org/biodiesel_make.html
General biodesiel information :
http://www.me.iastate.edu/biodiesel/pages/...biodiesel1.html
Other resources (discussion groups) :
http://www.topica.com/lists/straightcookingoilforfuel/
http://www.egroups.com/group/Biodiesel
European Biodiesel Board: Update on negotiations on biofuel directives (21 February 2003)
Additional biodiesel information :
Australia
Austria
Europe
Germany
United Kingdom
United states
A comprehensive review of problems of emissions and of small-, medium-, and industrial-scale production with numerous web resources and references may be found on the web :
Biodiesel : A brief overview
ADVANTAGES OF BIODIESEL
Blends of 20% biodiesel with 80% petroleum diesel can be used in unmodified diesel engines. Biodiesel can be used in its pure form but many require certain engine modifications to avoid maintenance and performance problems.
It was stated that about half of the biodiesel industry can use recycled oil or fat, the other half being soybean, or rapeseed oil according to the origin of these feed stocks.
Biodiesel is nontoxic, biodegradable. It reduces the emission of harmful pollutants (mainly particulates) from diesel engines (80% less CO2 emissions, 100% less sulfur dioxide) but emissions of nitrogen oxides (precursor of ozone) are increased.
Biodiesel has a high cetane number (above 100, compared to only 40 for diesel fuel). Cetane number is a measure of a fuel's ignition quality. The high cetane numbers of biodiesel contribute to easy cold starting and low idle noise.
The use of biodiesel can extend the life of diesel engines because it is more lubricating and, furthermore, power output are relatively unaffected by biodiesel.
Biodiesel replaces the exhaust odor of petroleum diesel with a more pleasant smell of popcorn or French fries.
By developing methods to use cheap and low quality lipids as feedstocks, it is hoped that a cheaper biodiesel can be produced, thus competing economically with petroleum resources.
Edited by eroyka - 4/3/2005, 09:02
alè, sto giro ci siamo....
sto finalmente provando ad andare al 100% di biodiesel del nuovo giro
(quello che è 20% etilestere di olio nuovo e 80%metilestere di olio fritto)
e devo dire che va molto bene e anche meglio di quello precedente
(che era tutto metilestere di olio nuovo)
una caratteristica di questo biodiesel è che l'ho fatto col sistema a due fasi (entrambe a catalisi basica)
anzichè in una sola fase....
evidentemente la cosa ha giovato anche se l'acqua di lavaggio ha rivelato un po' di scarto (emulsioni e saponi)
abbassando quindi la resa complessiva
(ma con dell'olio usato c'è da aspettarselo...)
ho riprovato ad accellerare a fondo in 3°... non fuma per nulla, neanche di notte con i fari della auto dietro
lo scarico non fa nessun odore (a parte appena accesso quando sa appena di olio scaldato)
la cosa che mi fa piacere è che la prontezza di avviamento a freddo (specie considerando questi giorni rigidi)
è migliorata rispetto al primo EMV prodotto....
in tutto per ora dispongo di una 50ina di litri... potrò fare una prova più approfondita ....
qualke litro lo dedicherò alla stufetta zibro a vedere se scalda lo stesso e soprattutto con meno puzza del kerosene...
Edited by belinassu - 5/3/2005, 00:34
Bravo Belinassu,
piacerebbe anche a me sperimentare, sto studiando e mi sono messo pesantemente alla ricerca di olio fritto ma senza risultato...
ciao a tutti
mi sono informato sul metanolo, sicuramente ho scoperto l'acqua calda, ma c'è da stare veramente attenti nel maneggiarlo, soprattutto in quanto è molto volatile e per inalazione da dei problemi molto seri.
Per quanto riguarda l'alcol etilico a 99,9 % ho trovato un fornitore di materiale per restauro che lo vende a 1,20 € al lt + iva in fusti da 25 lt zona Verona. se siete interessati fatemi sapere
Ho comprato i miei primi litri di olio di colza al lidl
a presto
Pierpaolo
Ciao PierPa,
il metanolo è altamente tossico non solo per inalazione ma viene assorbito attraverso la pelle provocando cecità e morte. Sicuramente non fa bene neanke ai pesci.
Ragazzi, per evitare la gelatina non si può fare il biodiesel in 2 o 3 fasi con l' etanolo?
Ke ne pensi Belinassu?
molto interessante l'etanolo assoluto a 1,2+iva (1,44 €) per 25 litri fa 36€ poi c'è la spedizione ....
non so, ....se fosse in zona sarebbe da provare cmq...
per l'uso dell'etanolo è auspicabile, ma dato che è più difficoltoso bisogna sviluppare un metodo efficace e sicuro
il problema è che non si ha sempre a che fare con lo steso tipo di olio (a meno di comprare sempre lo stesso olio nuovo, tipo colza)
per cui il metodo è difficile da mantenere, se non sviluppando una certa esperienza....
inoltre gli olii molto usati oltre ad avere meno resa devono essere tagliati con olio nuovo se si usa etanolo
perchè la reazione potrebbe non andare avanti....
insomma l'etanolo è meglio, ma è anche la via più dura e dispendiosa....
PS: l'auto come dicevo va molto bene ora ed è anche più silenziosa, però con la stufetta zibro
la maggiore temperatura di accensione crea problemi, probabilmente va miscelato un po' di kerosene
o meglio ancora modificata la stufetta in modo che il rapporto stechiometrico di combustione torni ottimale....
farò delle prove...
Edited by belinassu - 5/3/2005, 16:56
salve ragazzi sono nuovi del forum, vorrei chiedervi se e' possibile transesterificare i trigliceridi con l'olio di oliva visto che dalle mie zone si trova a palate.
non e' pero' quello industriale ma prodotto dai contadini.
CITAZIONE (saldelux @ 12/3/2005, 17:21)
Scusa ma a parte la Sansa e il suo olio, non è meglio usare l'olio di oliva naturale per l'alimentazione?
Comunque chi produce quintali di olio di oliva, produce quintali di sansa.
Armando
Edited by Armando de Para - 12/3/2005, 19:11
sto andando con il secondo giro di biodiesel e va tutto ok, sembra che l'auto di adatti al nuovo carburante
digerendolo sempre meglio....
purtroppo non tutte le ciambelle riescono col buco (di culo) e ho tentato di transesterificare 30 litri di olio di colza nuovo
anche se non avevo più abbastanza metanolo.......risultato.....
il biodiesel sembrava OK ma dovevo rendermi conto che c'era troppa poka glicerina (in sostanza ci sono rimasti troppi mono- e digliceridi)
per cui al primo lavaggio si è formata una emulsione lattiginosa inseparabile....
in sostanza 40 litri di roba nel cesso....
Il biodieslel è ua bella cosa ma bisogna sempre usare la testa e non farsi prendere troppo la mano dall'entusiasmo, se no si commettono errori...
..che si trasformano in uno spreco di tempo e risorse....
il prossimo giro dovrei poter fare un po' di biodiesel con l'olio di palma usato....
la cosa è molot interessante per em perchè è un olio solido a temperatura ambiente....
nel frattempo sto scrivendo una piccola guida delle mie prove
ciao;)
Anch'io ho saputo dai TG dell'olio di colza...ma per la benzina come funziona? Ho una opel corsa 1.0 a benzina, in quale percentuale devo aggiungere l'etanolo? E' easattamente quanto descritto nell'articolo di questo sito? Grazie in anticipo...
CITAZIONE (Malcy @ 14/3/2005, 15:20)
qui parliamo di biodiesel e sistemi connessi...
per l'etanolo ci sono già altre 3 discussioni aperte e molto esaurienti,
ti consiglio di consultare prima quelle
CITAZIONE (belinassu @ 13/3/2005, 01:45)
..che si trasformano in uno spreco di tempo e risorse....​
Ciao Belinassu,
ho trovato sulla rete un metodo per eseguire il rollback in caso di errore nella procedura di esterificazione, In sostanza un metodo per recuperare la "mappazza" lattiginosa creata per errore durante il procedimento di creazione del biodiesel.
Eccola qui, scusate ma e' in inglese
Jack Jones, from Utah, has found an ingenious way to break those nasty
cloudy looking white emulsions.
Really easy too!
1- Put your emulsified milky looking oil into a large container
(55 gallon drum, bucket, whatever you use)
2- Pour some leftover glycerine into the container (yeah, seriously!)
3- Stir a little bit & watch the emulsion separate into layers
4- Heat helps too
Jack has repeatedly been able to break emulsions this way.
For example:
I took him over 130 gallons of oil+emulsified Biodiesel+other stuff
He filled a 55 gallon drum half-way with my emulsified Biodiesel
(I had done a batch & made the mistake of misting it when it was too
cold--nice, white milky looking substance)
He poured about 5 gallons of glycerine (from his Biodiesel making)
into the drum, applied some heat w/ a fish tank heater (the kind you
heat large tropical aquariums with), & within a day or two the
emulsion broke. If the oil's warm sometimes the emulsion's been
breaking within hours.
Side Note:
This was emulsified oil that'd been sitting emulsified for over 3
months in a garage & hadn't separated (of course, the garage it was
sitting in was sub 40 deg. F over this 3 months).
He ran across this by accident. Threw some glycerine in a "botched
batch" and whoala, it separated the emulsion!
Anyway, he's purposely emulsified freshly processed Biodiesel just to
test the thing out. Over and over he's been able to break emulsions
by adding the glycerine to it.
The great thing is, the Glycerine falls to the bottom, ya drain it
off, drain off the water that's ALSO now separated out & fallen to
the bottom, and your left w/ Biodiesel!!!
Anyway, it's been working great for him.
Beat's the crap out of trying to wash w/ warm water over & over, add
vineagar, or salt, or all the other things. Also, works quicker than
anything else he's run across.
Give it a try & see if it'll break your emulsions.
I'm a believer! 130+ Gallons of botched oil is now 110 Gallons of
GOOD Biodiesel! (yeah, 20 gallons of water dropped out)
Graydon Blair
Way out in Utah
cavoli non ho provato ....
la glicerina l'avevo....
ma ormai è tardi....ho buttato tutto nella fossa biologica......
cmq ottimo a sapersi per i prossimi evantuali incidenti....
grazie!
lo vendono come carburante per modellini a scoppio,
io l'ho preso online, ma se si ha fortuna si ha un rivenditore vicino
e si risparmia sulla spedizione (che per quelle merci li è costosa)
purtroppo ho finito il biodiesel e sono tornato al gasolio (con 20% di olio)
ma è una tragedia,andava molto meglio il biodiesel.... e adesso come mi riabbituo al "trattore"....?
a tutti gli interessati ad una pagina web in italiano per una spiegazione sulla produzione di biodiesel segnalo questo QUI
date un occhio anche al resto del sito che è interessante...
CITAZIONE (belinassu @ 20/3/2005, 21:30)
date un occhio anche al resto del sito che è interessante...​
Scusate ma in questa maniera quanto viene a costare il biodiesel? dov' è il risparmio?
QUOTE (gino @ 20/3/2005, 22:44)
QUOTE (belinassu @ 20/3/2005, 21:30)
Scusate ma in questa maniera quanto viene a costare il biodiesel? dov' è il risparmio?​
...non sarai mica uno di quelli che è andato a svuotare gli scaffali della colza appena ha visto il TG ???
il risparmio è esiguo se non nullo (a meno di usare olii usati trovati gratis), la caratteristica peculiare di questo carburante
è che è più ecosostenibile e una fonte di energia rinnovabile, e abbatte drasticamente le emissioni allo scarico...
il fattore risparmio (che è cmq minimamente presente) passa in secondo piano
Stato
