ho effettuato il collegamento e ho provato a far funzionare il tutto.
Con scarsi risultati
mi da il seguente messaggio di errore
al comando $ aurora -a 2 -e /dev/ttyS1
20120425-17:37:41: aurora : Problme flushing serial device: (5) Input/output error
20120425-17:37:41: aurora : Problem configuring serial device
Qualcuno mi può aiutare?
Ale
ho fatto quest'altro tentativo
morpheus@morpheus:/dev$ aurora -b -a 2 -e /dev/ttyUSB0
szttyDevice: /dev/ttyUSB0
yDelay: 1
yTimeout 0 us
devLCKfile:
devLCKfileNew:
RunTime 20120425-18:01:26 v1.7.0
PID : 2019
Attempting to get lock on Serial Port /dev/ttyUSB0...
rPID: 2019 SubStrPos: aurora command: aurora Appears we got the lock.
Opening Serial Port /dev/ttyUSB0... Serial Port /dev/ttyUSB0 successfully opened.
Configuring serial device... Flushing unread data first... Success!
Flushing serial device buffer... Success!
Comm Check: Let's see if the Aurora is listening...
Elapsed time since last comm 0 us
Attempt 1
Clearing read buffer RC=0 (00):ch=0 Success!
szSerBufferSave OK! 02 3a 00 20 20 20 20 20 20 20
command: 02 3a 00 20 20 20 20 20 c9 59
Sending command... sent 10 characters
Draining serial device buffer... Success!
Cleared data buffer: 20 20 20 20 20 20 20 20 20 20
read attempts 1 timeout 0us RC=1 (bf)
read attempts 2 timeout 0us RC=1 (bd)
read attempts 3 timeout 0us RC=1 (bf)
read attempts 4 timeout 0us RC=1 (bf)
read attempts 5 timeout 0us RC=1 (bf)
read attempts 6 timeout 0us RC=1 (bf)
read attempts 7 timeout 0us RC=1 (bf)
read attempts 8 timeout 0us RC=1 (6d)
answer: bf bd bf bf bf bf bf 6d
received 8 characters
Comm Check: Failure, aborting...
rc: -1
Restoring Serial Port settings /dev/ttyUSB0... Success!
Closing Serial Port /dev/ttyUSB0... Success!
devLCKfile
devLCKfileNew
Clearing Serial Port Lock (2019)... done.
Complete.
grazie a tutti quelli che vorranno gentilmente rispondere
il mio sistemino è così composto
1) pandaboard ES
2) software installato debian wheezy
3) versione aurora 1.8
4) adattatore Usb <> rs-485
5) collegamento lato usb : T+ e T-
6) collegamento lato inverter :T+, T- e LNK per lo schermo del cavo twistato.
La dev giusta è ttyUSB0 .... compare e scompare attaccando e staccando l'usb.
questo è il risultato
root@omap:~# aurora -a 2 -e /dev/ttyUSB0
20120505-05:41:27: aurora: No response after 1 attempts
20120505-05:41:27: aurora: ERROR: Received bad return code (-1 0)
1) pandaboard ES
Brancolo nel buio ..... qualcuno mi può aiutare?
Ale
scusate ... se può servire ho aggiunto -b
root@omap:~# aurora -a 2 -b -e /dev/ttyUSB0
RunTime 20120505-05:54:31 v1.8.0
Endian : Little
PID : 2472
Checking for lock
Checking process 2472 for lock
rPID: 2472 SubStrPos: aurora command: aurora = me
Attempt 1
Clearing read buffer Success!
szSerBufferSave OK! 02 3a 00 00 00 00 00 00 00 00
command: 02 3a 00 00 00 00 00 00 01 b7
Cleared data buffer: 00 00 00 00 00 00 00 00 00 00
Read char #1 RC=1 (fd) waited/max 519/1000000 uS
Read char #2 RC=1 (dd) waited/max 305/1000000 uS
Read char #3 RC=0 (00) waited/max 106171/1000000 uS
answer: Got -1 characters
devLCKfile:
devLCKfileNew:
Clearing Serial Port Lock (2472)... done.
20120505-05:54:31: aurora: ERROR: Received bad return code (-1 0)
Ciao babyporch, hanno iniziato le spedizioni del Raspberry Pi (Un mini-computer da 30$) , sono tentatatissimo nel prenderne uno ed utilizzarlo per monitorare il fotovoltaico, 30$, un convertitore rs485-usb da pochi $ e sarei a posto! Inoltre consuma 2-3watt e non sarebbe un problema lasciarlo acceso 24/7.
Mi chiedevo però se il tuo software fosse compatibile con uno o alcuni di questi sistemi operativi qui (che per l'appunto sono compatibili con il Raspberry Pi, anche se immagino ne usciranno altri nel futuro)
..... sarebbe un a grossa delusione se su windows funzionasse ...ma tant'è .... provo e ti faccio sapere..
P.S. lanciando il comando 4 o 5 volte di fila ho notato che le righe sottolineate
Cleared data buffer: 00 00 00 00 00 00 00 00 00 00 Read char #1 RC=1 (fd) waited/max 519/1000000 uS
cambiano di volta in volta (sia come numero che come valori) anche se la sequenza termina sempre con
la sensazione è che "provino a parlarsi ma non si capiscano" ... se mi passi i termini....
se provassi con un convertitore rs845 <> RS232?
il pandaboard ha una porta 232 ....
tempo e soldi buttati?
Che tu sappia ha mai provato nessuno con una pandaborard o similari (beagle, hawk, ecc...) ovvero con il chip ARM?
Grazie ancora
Ale
Ciao babyporch
non so come prenderla ma anche con w IDENTICO risultato
...a questo punto incriminerei il convertitore.... che dici?
provo con un 232 e faccio sapere...
Grazie ancora
P.S.
X Cente :sto anche io aspettando impazientemente il raspberry. Come fai a sapere che stanno iniziando a consegnare?
Non ho l'esperienza di babyporch ma il software aurora su debian wheezy sembra girare per cui presumo (e spero) OK anche per raspberry.
Peccato debba avere un alimentatore esterno.....
aggiungo : anche il contenitore quindi sono altri 15 euro per tutti e due e se li trovi in negozio altrimenti altre ss.
Alimentatore --> alimentatore di un hub usb, ne ho parecchi a casa --> 0€
Case --> mi faccio una scatoletta in plastica con la prima cosa che trovo --> 0€
In più potrei prendere la versione da 20€ e risparmiare ancora di più.
E si è vero non si trova ma io non ho nessuna fretta.
Non c'è nessun problema infatti, abbiamo solo detto che non si trovano, io mi sono iscritto sul sito rs da diversi mesi ma ancora niente, sono ancora in attesa del mio lotto che sarà chissa' fra quanto tempo, la distribuzione al momento è col contagocce.A meno che uno non sia un folle e lo prenda su ebay da qualcuno che se lo rivende, sopratutto in inghilterra, ma a certi prezzi, ho visto offerte arrivare a più di 150€, chi lo prende a quel prezzo è un pazzo.....
Baby , perche' stai usando la ver. 1 sul tuo sito in firma? Non e' meglio la 2.... adesso appena mi arriva l'altro Pogo , provo a metterci la v.2 , rispetto all'altro ha qualcosa di piu' , anche se gli manca (o almeno non mi e' riuscito trovarla) la possibilita' di passare da un giorno ad un altro , qlc mese addietro) senza dovere saltare gg. x gg. .....
Ciao sto' provando ad installare la tua sul Pogoplug se e appena ci riesco te lo comunico......
Un'aggiuntina se volessi passare dalla data odierna al (per esempio) 10 ottobre 2011 come faccio ?
Naturalmente era il problema se vado sul mese dovrei poter accedere ad un giorno cliccandoci sopra , lo stesso per l'anno saltando al mese che interessa.... altrimenti scorrere giorno x giorno diventa un casino :d grazie
Comunque ho fatto una chiavetta anche con la tua versione nel Pogo , la simulazione funziona tutto , domani dovrei provarla connessa all'inverter..... segue....
Ciao baby....da un po che non ci sentiamo.
Vorrei ricreare quello che hai fatto tu con la cartella /new col nuovo logger.
Ho messo nella cartella WWW la cartella del nuovo logger rinominandola come new.
Ma quando dal browser lancio il comando mi esce la finestra del nuovo logger senza il grafico escono solo i dati della produzione in basso...come mai??
Impianto 5,52 Kw Tot. Integrato allacciato il 29/12/2010Azimut: SSE 160° - Tilt: 25°N. 24 pannelli policristallini BP Solar Endura BP-3230TInverter Power-One PVI-6000-OUTD-S-IT [COLOR=#ff0000]- Updated - Castrignano de Greci (LE) www.castrignanometeo.eu:biker:
Grazie Baby....
Inoltre se vedi sul link che ho allegato i grafici mensili ed annuali non escono...
Devo aggiornare qualcosa nel crotab??
Vorrei rendere completamente funzionante la nuova versione.
Giobbe
Baby, delle sintesi mensile ed annuale cosa mi dici...
Praticamente quella mensile non si vede il mese corrente, mentre aprile, marzo si vede bene.
Quella annuale non si vede proprio neanche il 2011
Ciao a tutti, non so da quanto tempo non è stato aggiornato questo forum ma mi sembra abbastanza interessante. Io ho installato la versione "Aurora PowerOne Web Data Logger" di Babyporch e devo dire veramente COMPLIMENTI hai fatto un ottimo lavoro. Ma io volevo condividere con voi il logger che io ho fatto in MYSQL per la lettura di più di un inverter, ho creato due tabelle una per "#aurora -a 2 -c -e /dev/ttyUSB0" e una per "#aurora -a 2 -c -d0 /dev/ttyUSB0", in allegato troverete i due fatti in "python". L'unica cosa volevo il vostro aiuto per creare la parte grafica cosi carina come l'ha fatto Babyporch, se qualcuno le possono servire questi file e se qualcuno mi puo dare una mano, li sarebbe molto grato.
nel mio caso ho configurato i file .py con 16 inverter. però basta modificare quella riga e mettere la quantità voluta. filepython.zipfilepython.zip
ma scusa ma perchè non ti integri al lavori di baby: usi il suo applicativo per vedere i grafici e da python leggi i file .dat che produce e li importi in mysql, oppure modifichi il lavoro di baby per andare a leggere da mysql.
io avevo cominciato a provare l'importazione dei .dat in mysql usando mysqlimport ma poi mi sono fermato.
