Aurora Web Data Logger open source - EnergeticAmbiente.it
  • Ho installato openWRT sul mio router Netgear DG834G v2. Come convertitore ho la ezl70.
    Qualcuno mi aiuta ad andare avanti?
    http://fabiusmontana.dtdns.net/123solar/index_mono.php
    • sto impazzendo
      Originariamente inviato da alex28 Visualizza il messaggio
      Ciao a tutti,
      ho effettuato il collegamento e ho provato a far funzionare il tutto.
      Con scarsi risultati
      mi da il seguente messaggio di errore
      al comando $ aurora -a 2 -e /dev/ttyS1
      20120425-17:37:41: aurora : Problme flushing serial device: (5) Input/output error
      20120425-17:37:41: aurora : Problem configuring serial device
      Qualcuno mi può aiutare?
      Ale
      ho fatto quest'altro tentativo
      morpheus@morpheus:/dev$ aurora -b -a 2 -e /dev/ttyUSB0
      szttyDevice: /dev/ttyUSB0
      yDelay: 1
      yTimeout 0 us
      devLCKfile:
      devLCKfileNew:
      RunTime 20120425-18:01:26 v1.7.0
      PID : 2019
      Attempting to get lock on Serial Port /dev/ttyUSB0...
      rPID: 2019 SubStrPos: aurora command: aurora Appears we got the lock.
      Opening Serial Port /dev/ttyUSB0... Serial Port /dev/ttyUSB0 successfully opened.
      Configuring serial device... Flushing unread data first... Success!
      Flushing serial device buffer... Success!
      Comm Check: Let's see if the Aurora is listening...
      Elapsed time since last comm 0 us
      Attempt 1
      Clearing read buffer RC=0 (00):ch=0 Success!
      szSerBufferSave OK! 02 3a 00 20 20 20 20 20 20 20
      command: 02 3a 00 20 20 20 20 20 c9 59
      Sending command... sent 10 characters
      Draining serial device buffer... Success!
      Cleared data buffer: 20 20 20 20 20 20 20 20 20 20
      read attempts 1 timeout 0us RC=1 (bf)
      read attempts 2 timeout 0us RC=1 (bd)
      read attempts 3 timeout 0us RC=1 (bf)
      read attempts 4 timeout 0us RC=1 (bf)
      read attempts 5 timeout 0us RC=1 (bf)
      read attempts 6 timeout 0us RC=1 (bf)
      read attempts 7 timeout 0us RC=1 (bf)
      read attempts 8 timeout 0us RC=1 (6d)
      answer: bf bd bf bf bf bf bf 6d
      received 8 characters
      Comm Check: Failure, aborting...
      rc: -1
      Restoring Serial Port settings /dev/ttyUSB0... Success!
      Closing Serial Port /dev/ttyUSB0... Success!
      devLCKfile
      devLCKfileNew
      Clearing Serial Port Lock (2019)... done.
      Complete.
      grazie a tutti quelli che vorranno gentilmente rispondere
      Ciao a tutti,
      il mio sistemino è così composto
      1) pandaboard ES
      2) software installato debian wheezy
      3) versione aurora 1.8
      4) adattatore Usb <> rs-485
      5) collegamento lato usb : T+ e T-
      6) collegamento lato inverter :T+, T- e LNK per lo schermo del cavo twistato.
      La dev giusta è ttyUSB0 .... compare e scompare attaccando e staccando l'usb.
      questo è il risultato
      root@omap:~# aurora -a 2 -e /dev/ttyUSB0
      20120505-05:41:27: aurora: No response after 1 attempts
      20120505-05:41:27: aurora: ERROR: Received bad return code (-1 0)
      Brancolo nel buio ..... qualcuno mi può aiutare?
      Ale
      • Hai provato il convertitore su windows? Se lì funziona ne riparliamo (potrebbe essere la versione di aurora, errore già visto su una cpu via c3)
        2,99 KWp - 13 moduli Solarworld SW230+ mono black - Inverter PowerOne Aurora PVI 3.0 OUTD - Località Cefalù- Tilt 35° - Azimut -6° EST
        Il mio impianto online: http://valerianet.dyndns.org/
        e su http://www.rendimento-solare.eu/it/c...353/14293.html
        • Originariamente inviato da alex28 Visualizza il messaggio
          Ciao a tutti,
          1) pandaboard ES
          Ale
          scusate ... se può servire ho aggiunto -b
          root@omap:~# aurora -a 2 -b -e /dev/ttyUSB0
          yDelay: 1
          yTimeout 0 mS
          yMaxRunTime ~
          devLCKfile:
          devLCKfileNew:
          Got Params
          RunTime 20120505-05:54:31 v1.8.0
          Endian : Little
          PID : 2472
          Checking for lock
          Checking process 2472 for lock
          rPID: 2472 SubStrPos: aurora command: aurora = me
          Attempt 1
          Clearing read buffer Success!
          szSerBufferSave OK! 02 3a 00 00 00 00 00 00 00 00
          command: 02 3a 00 00 00 00 00 00 01 b7
          Cleared data buffer: 00 00 00 00 00 00 00 00 00 00
          Read char #1 RC=1 (fd) waited/max 519/1000000 uS
          Read char #2 RC=1 (dd) waited/max 305/1000000 uS
          Read char #3 RC=0 (00) waited/max 106171/1000000 uS
          answer: Got -1 characters
          devLCKfile:
          devLCKfileNew:
          Clearing Serial Port Lock (2472)... done.
          20120505-05:54:31: aurora: ERROR: Received bad return code (-1 0)
          Complete 20120505-05:54:31
          • sto impazzendo
            Originariamente inviato da babyporch Visualizza il messaggio
            Grazie per la velocissima risposta....
            ..... sarebbe un a grossa delusione se su windows funzionasse ...ma tant'è .... provo e ti faccio sapere..
            P.S. lanciando il comando 4 o 5 volte di fila ho notato che le righe sottolineate
            cambiano di volta in volta (sia come numero che come valori) anche se la sequenza termina sempre con
            la sensazione è che "provino a parlarsi ma non si capiscano" ... se mi passi i termini....
            se provassi con un convertitore rs845 <> RS232?
            il pandaboard ha una porta 232 ....
            tempo e soldi buttati?
            Che tu sappia ha mai provato nessuno con una pandaborard o similari (beagle, hawk, ecc...) ovvero con il chip ARM?
            Grazie ancora
            Ale
            • Ciao babyporch, hanno iniziato le spedizioni del Raspberry Pi (Un mini-computer da 30$) , sono tentatatissimo nel prenderne uno ed utilizzarlo per monitorare il fotovoltaico, 30$, un convertitore rs485-usb da pochi $ e sarei a posto! Inoltre consuma 2-3watt e non sarebbe un problema lasciarlo acceso 24/7.
              Mi chiedevo però se il tuo software fosse compatibile con uno o alcuni di questi sistemi operativi qui (che per l'appunto sono compatibili con il Raspberry Pi, anche se immagino ne usciranno altri nel futuro)
              Grazie mille e ciao!
              6kWp (26x Winaico WSP-230 P6) inclinazione 0°
              Inverter Aurora PVI-6000-OUTD Fotografia impianto
              Andamento produzione: http://cente.no-ip.biz
              • sto impazzendo 2.0
                Grazie ancora
                Ale
                Ciao babyporch
                non so come prenderla ma anche con w IDENTICO risultato
                ...a questo punto incriminerei il convertitore.... che dici?
                provo con un 232 e faccio sapere...
                Grazie ancora
                P.S.
                X Cente :sto anche io aspettando impazientemente il raspberry. Come fai a sapere che stanno iniziando a consegnare?
                Non ho l'esperienza di babyporch ma il software aurora su debian wheezy sembra girare per cui presumo (e spero) OK anche per raspberry.
                • x cente https://www.energeticambiente.it/tec...alogger-1.html
                  AUTO BANNATO
                  • Preferirei andare sul Rasperry Pi, costa meno, consuma meno, ed è meno ingombrante.
                    • Peccato che non si trovi, io sono in attesa da un pezzo...
                      Impianto FV 5,52 kWp, 230°, 11° tilt, 24 moduli Solaria S6M2G230, inverter SMA SB-5000-TL http://www.pvoutput.org/list.jsp?userid=8233
                      • Originariamente inviato da Cente Visualizza il messaggio
                        Peccato debba avere un alimentatore esterno.....
                        aggiungo : anche il contenitore quindi sono altri 15 euro per tutti e due e se li trovi in negozio altrimenti altre ss.
                        Ultima modifica di spider61; 06-05-2012, 09:39.
                        AUTO BANNATO
                        • Originariamente inviato da spider61 Visualizza il messaggio
                          Alimentatore --> alimentatore di un hub usb, ne ho parecchi a casa --> 0€
                          Case --> mi faccio una scatoletta in plastica con la prima cosa che trovo --> 0€
                          In più potrei prendere la versione da 20€ e risparmiare ancora di più.
                          E si è vero non si trova ma io non ho nessuna fretta.
                          • E noi ne abbiamo ancora meno... di fretta !
                            AUTO BANNATO
                            • Non capisco dov'è il problema nel prendere un Rasbperry Pi, io voglio un data logger con la minima spesa, tutto quì.
                              • Non c'è nessun problema infatti, abbiamo solo detto che non si trovano, io mi sono iscritto sul sito rs da diversi mesi ma ancora niente, sono ancora in attesa del mio lotto che sarà chissa' fra quanto tempo, la distribuzione al momento è col contagocce.A meno che uno non sia un folle e lo prenda su ebay da qualcuno che se lo rivende, sopratutto in inghilterra, ma a certi prezzi, ho visto offerte arrivare a più di 150€, chi lo prende a quel prezzo è un pazzo.....
                                • @alex28: è il convertitore il problema, cerca uno rs485->rs232 con solo tre fili e sei apposto (circa € 2 su ebay)
                                  P.S Debian e Ubuntu stessa pasta quindi nessun problema
                                  • Baby , perche' stai usando la ver. 1 sul tuo sito in firma? Non e' meglio la 2.... adesso appena mi arriva l'altro Pogo , provo a metterci la v.2 , rispetto all'altro ha qualcosa di piu' , anche se gli manca (o almeno non mi e' riuscito trovarla) la possibilita' di passare da un giorno ad un altro , qlc mese addietro) senza dovere saltare gg. x gg. .....
                                    AUTO BANNATO
                                    • Le uso tutte due l'url classico è la versione stabile, aggiungendo /new all'url finale ho la nuova di sviluppo
                                      • Ciao sto' provando ad installare la tua sul Pogoplug se e appena ci riesco te lo comunico......
                                        Un'aggiuntina se volessi passare dalla data odierna al (per esempio) 10 ottobre 2011 come faccio ?
                                        AUTO BANNATO
                                        • Non ci avevo pensato.
                                          Nella lista delle cose da fare.
                                          • Naturalmente era il problema se vado sul mese dovrei poter accedere ad un giorno cliccandoci sopra , lo stesso per l'anno saltando al mese che interessa.... altrimenti scorrere giorno x giorno diventa un casino :d grazie
                                            Comunque ho fatto una chiavetta anche con la tua versione nel Pogo , la simulazione funziona tutto , domani dovrei provarla connessa all'inverter..... segue....
                                            AUTO BANNATO
                                            • Ciao baby....da un po che non ci sentiamo.
                                              Vorrei ricreare quello che hai fatto tu con la cartella /new col nuovo logger.
                                              Ho messo nella cartella WWW la cartella del nuovo logger rinominandola come new.
                                              Ma quando dal browser lancio il comando mi esce la finestra del nuovo logger senza il grafico escono solo i dati della produzione in basso...come mai??
Nome:   Immagine.jpg
Visite: 1
Dimensione: 182.3 KB
                                              Impianto 5,52 Kw Tot. Integrato allacciato il 29/12/2010 Azimut: SSE 160° - Tilt: 25° N. 24 pannelli policristallini BP Solar Endura BP-3230T Inverter Power-One PVI-6000-OUTD-S-IT [COLOR=#ff0000]- Updated - Castrignano de Greci (LE) www.castrignanometeo.eu:biker:
                                              • Ciao giobbe70, devi scaricarti le librerie javascript highcharts e scompattarle nella directory js direttamente in new
                                                • Ok fatto tutto Ok
                                                  solo che come picco del grafico esce 3500W ho settato in config.inc 6500 ma non lo prende...
                                                  Ultima modifica di giobbe70; 13-05-2012, 18:42.
                                                  • Patch daily.php riga 299, sostituisci con:
                                                    codice:
                                                          max: #@php print $maxkwh?>,
                                                    Ciao.
                                                    P.S. l'editor del forum mi sega il codice: sostiuisci #@ con < seguito da ? senza spazio
                                                    Ultima modifica di babyporch; 14-05-2012, 10:43.
                                                    • Grazie Baby....
                                                      Inoltre se vedi sul link che ho allegato i grafici mensili ed annuali non escono...
                                                      Devo aggiornare qualcosa nel crotab??
                                                      Vorrei rendere completamente funzionante la nuova versione.
                                                      Giobbe
                                                      • risolto scusa
                                                        • Baby, delle sintesi mensile ed annuale cosa mi dici...
                                                          Praticamente quella mensile non si vede il mese corrente, mentre aprile, marzo si vede bene.
                                                          Quella annuale non si vede proprio neanche il 2011
                                                          • Aurora PowerOne Web Data Logger
                                                            Ciao a tutti, non so da quanto tempo non è stato aggiornato questo forum ma mi sembra abbastanza interessante. Io ho installato la versione "Aurora PowerOne Web Data Logger" di Babyporch e devo dire veramente COMPLIMENTI hai fatto un ottimo lavoro. Ma io volevo condividere con voi il logger che io ho fatto in MYSQL per la lettura di più di un inverter, ho creato due tabelle una per "#aurora -a 2 -c -e /dev/ttyUSB0" e una per "#aurora -a 2 -c -d0 /dev/ttyUSB0", in allegato troverete i due fatti in "python". L'unica cosa volevo il vostro aiuto per creare la parte grafica cosi carina come l'ha fatto Babyporch, se qualcuno le possono servire questi file e se qualcuno mi puo dare una mano, li sarebbe molto grato.
                                                            nel mio caso ho configurato i file .py con 16 inverter. però basta modificare quella riga e mettere la quantità voluta.
                                                            filepython.zipfilepython.zip
                                                            • ma scusa ma perchè non ti integri al lavori di baby: usi il suo applicativo per vedere i grafici e da python leggi i file .dat che produce e li importi in mysql, oppure modifichi il lavoro di baby per andare a leggere da mysql.
                                                              io avevo cominciato a provare l'importazione dei .dat in mysql usando mysqlimport ma poi mi sono fermato.
